ducatipaso.org • View topic - ignition switch comapatibality
It is currently Mon Jun 15, 2026 2:22 pm
 Post subject: ignition switch comapatibality
PostPosted: Sun Sep 04, 2005 10:00 pm
Does any body know if the ignition swith off of a 907ie will fit a 88 750 paso ?
PostPosted: Mon Sep 05, 2005 7:50 am
no, they are different. The mounting holes don`t match.
Gerhard
PostPosted: Tue Sep 20, 2005 4:53 pm
It worked. It just seats a little lower in the hole but it works. I added two (1 m.m.)washers under the mounting to align the lock hole with the pin. The electrical connection is the same and plugs right in. No modification is needed.
PostPosted: Tue Sep 20, 2005 7:41 pm
good to know then I probably just got the wrong info, sorry.
PostPosted: Mon Oct 03, 2005 7:36 pm
Does anyone know what other locks might fit onto the paso without much work?
Also which if any of the locks use the same key/s, or are the ignition, tank and seat all the same key???
PostPosted: Tue Oct 04, 2005 9:02 am
:cool:
The ignition, tank and seat use three different keys. There is some information about key blanks in Registered User Menu (on the left of the screen) > Links > Ducati Paso technical sources > David Harvey's Paso Section - scroll down to 'Links' and find Ducati Owners Club of (GB) Parts Interchangeability List. There may be other leads to information in the same area.
PostPosted: Tue Oct 04, 2005 11:16 am
thanks skins i just needed to know whether any of the locks were linked by a key... I need to replace a main ignition cylinder and having three different locks makes things much easier.
i guess i should be able to get keys made up from the lock numbers of the other items (seat and tank). not the easiest of tricks but there's no rush.
someone had mentioned keycutting service a while back so i chased it up a little myself http://www.motorcycle-keys.com/
PostPosted: Sun Oct 09, 2005 10:54 am
PostPosted: Mon Oct 10, 2005 2:58 am
Redpaso
PostPosted: Mon Oct 10, 2005 10:56 pm
PostPosted: Tue Oct 11, 2005 12:16 am
PostPosted: Tue Oct 11, 2005 3:46 pm
