ducatipaso.org • View topic - regs and wires
It is currently Sun Jun 21, 2026 2:23 pm
 Post subject: regs and wires
PostPosted: Mon Aug 01, 2011 4:58 pm
When i changed from the original regulator on my paso i was left with 2 green wires a red wire and a pink wire. ....what are these for? anyone!
does the pink have to be grounded for the bike to charge? is this the batt charge light?
all these wires are left in the original conector left side-open.
also when i tried the wiring upgrade i was only half succesful-the coil end didnt work for me.
ive noticed avatars photos were intresting as the block showed one red on top(same)a brown(where my black is)another brown underneath(mine is red)and so are the blocks different? as wires must be different for each persons bike.
my bike was okay to ride home after my crash as the dash lit up-but now i come to try it no dash lights or ignition.
now another funny thing the engine WILL try to turn over with kill switch off!!! still no dash lights though.
HEELLLP!
 Post subject: Re: regs and wires
PostPosted: Thu Aug 04, 2011 11:07 am
Dave, did you have a look at the wiring plan ?
The two green wires are the ones that come from the alternator, as does the red one. The pink wires is for the batt. charging light. I wonder how your new regulator works if these wires are still unused ?!
Do not ground the batt. charging light if it is unused !
I`m not sure I understand your comments about the coil wiring.
It is actually very easy.
My guess is what you describe as brown are the discoloured orange wires.
I must admit that at the moment I`m not sure if it`s normal that the starter motor runs also with kill switch on OFF as what it mainly does is kill the ignition. (cut the 12V to the coils)
Does your headlight and taillight work ?
PostPosted: Sat Aug 06, 2011 12:43 pm
PostPosted: Mon Aug 15, 2011 8:43 am
dont be shy lads anything would be appreciated!!!
PostPosted: Mon Aug 15, 2011 9:54 am
This is from the downloads section, J.
