ducatipaso.org • View topic - firs bike..bettery wont stay charged while riding?
It is currently Tue Sep 30, 2025 11:19 am
 Post subject: firs bike..bettery wont stay charged while riding?
PostPosted: Sat Aug 27, 2011 8:54 pm
I have a 1990 paso 906. Its my first bike. Had to put new MC and clutch in it. Took it out for the first time, rode it a couple miles and it died. No power at all when I turn the key on. Completely dead. Re charged the battery and it fired right up. How do I check the regulator rectifier? It keeps blowing one of the two 7.5 amp fuses under the seat too.. any help? I want to ride this bad boy..
 Post subject: Re: firs bike..bettery wont stay charged while riding?
PostPosted: Sat Aug 27, 2011 9:09 pm
BATTERY. :banghead:
PostPosted: Sat Aug 27, 2011 9:41 pm
check the FAQs on top of the P750 forum.
PostPosted: Sat Aug 27, 2011 10:47 pm
Ok thanks. Any ideas why my 7.5 amp fuse keeps blowing. Its a wire that runs off the positive side of my battery, about 6the inches up the red wire there is where the fuse plugs in. Then it runs in to the harness towards the front of the bike. Could this fuses blowing be the issue with the battery not staying charged . Or any ideas on what that wire with the fuse actually goes to? Sorry if my questions are dumb. First bike and not experienced with electrical issues and my manual doesn't specifi what the fuse is for from what I see in the sh.tty manual I have in five different languages. :wacko:
PostPosted: Mon Sep 12, 2011 7:07 pm
PostPosted: Mon Sep 12, 2011 7:29 pm
Got some work to do :thumbup:
Check your ground connections first,eliminate any signs of corrosion or loose connections. Once you have that done,the real work will begin,checking every single connection. Sounds worse than it is, most parts are cheap but it will take time.
It will however be time well spent. In the end you will have a rare beast, an 20 year old Italian bike free of electrical issues,something to be very proud off :thumbup:
One other thing to note, the reigning gods of Ducati will save a place in Ducati heaven just for you :beer: :beer:
PostPosted: Tue Sep 13, 2011 11:28 pm
Hey thanks for responding guys. Im from USA Missouri. I was told italy only made 3000 blue 906's in 89 &90 and they sent 111 of them to USA? Is this true or did I get fed full of BS? Well either way I have one. Yeah ill check out the rubbers on the dash. I got a new speedo cable because nothing works except the rpm gauge. Replaced the cable and no change. So maybe there is some wire problems with the dash causing the 7.5 amp to blow. I was told it had a new wiring and harness in 06. So hopefully its something simple.
PostPosted: Mon Sep 19, 2011 8:35 am
Users browsing this forum: No registered users and 22 guests
