It is currently Sat Apr 25, 2026 7:21 am
 Post subject: Which bearing type for swingarm?
PostPosted: Sun Aug 28, 2011 8:37 am
Hi guys,
i need the type/naming of all swingarm bearings & shaft seals.
I do not want to buy them at ducati. They`d cost more than the swingarm itself.
Anyone knows?
Here the original part #s:
764000001
041202295
751632054
075549265
764000002
Johannes
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
 Post subject: Re: Which bearing type for swingarm?
PostPosted: Tue Sep 06, 2011 8:35 pm
I have only had to replace the bearing and seals for the shock linkage - 5 bearings total. The gearbox/frame pivot bearings were OK so I don't know the exact size for them (the right side is a double sealed type). If this is familiar then I can quote the linkage sizes.
PostPosted: Tue Sep 06, 2011 8:54 pm
you find them all listed in the FAQs
http://ducatipaso.org/forum/viewtopic.p ... c&start=15
all swingarm bearings are the same on P750/906 & 907ie.
PostPosted: Thu Sep 15, 2011 11:55 pm
The numbers I retrieved from my swing arm are as follows:
075549265: 26mm x 20mm x 4mm seal
764000002: 260D 201D 18L bearing
Sorry I don't have the others...
Lloyd
'91 907ie
'96 900 SS SP
'97 900 SS CR (for sale)
'74 750 GT (since new - sort of)
'85 Pantah 600 (sold, but not forgotten)
PostPosted: Fri Sep 16, 2011 12:25 am
Oops!
The others were on the previous page! I can see also some were not part numbers but sizes for the bearings. Let's try again:
764000001: 32mm OD x 25mm ID x 18mm L needle bearing
041202295: 32mm x 25mm x 4mm seal
751632054: #630004 2RS1C3
764000002: 26mm OD x 20mm ID x 18mm L needle bearing
Again, these were taken from my swingarm components
'91 907ie
'96 900 SS SP
PostPosted: Sun Sep 18, 2011 4:02 pm
Aftermarket bearing sizes then :
Mfr SKF Bearings
Swingarm linkage bearings are 4 x HK2020 Needle bearing,1 x HK2030 Needle bearing and 6 x G20x26x4 Seal
Sprocket Carrier (always a good idea)
2 x 6005 2RS1
