ducatipaso.org • View topic - Rev. counter gears part#066792160
It is currently Wed Mar 04, 2026 9:25 pm
 Post subject: Rev. counter gears part#066792160
PostPosted: Sun Sep 11, 2011 10:13 am
Hello Gents.
The rev. counter gears, part#066792160 on my 907 are worn out and of course canceled by Ducati :,(
does anybody have a set lying around or have a lead on where i could find a set?
Also interested in a good used set, all pasos use the same gears.
parts# 13
Uploaded with
Håvard
 Post subject: Re: Rev. counter gears part#066792160
PostPosted: Mon Sep 12, 2011 7:04 am
I can`t see the picture, but when you are looking for what i am thinking of....
When i find my old working revcounter, you can have it. I replaced the drive by an elecronic drive...
(And also have a brand new one for spare :evil: )
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Mon Sep 12, 2011 5:25 pm
Hi.
Very thankful if you find it, send me a pm if you do so we can work something out.
I am not sure if i need both gears since I haven't opened it up yet other than removing the “male” gear and pin witch the cable attaches to and know that is worn,
but I don't know if the “female” gear that goes on the camshaft is worn also but guess it would be recommended to change both.
Do you have any more info on your electronic setup, what kind of tachometer are you using?
Thanks, Håvard
Edit, just re-read your build thread :thumbup: :thumbup: :thumbup:
