It is currently Sun Mar 01, 2026 11:17 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: testing ignition pickups
PostPosted: Sat Sep 10, 2011 6:00 pm
Good job
It always pays to do the basics first :thumbup:
Most electrical issues come down to simple connections issues
Always check those power supply and grounds...90% of all problems can be fixed by these simple checks even on the most complicated machinary. A bad ground will fry expensive parts very quickly, if power can't go to its assigned ground it will find its own
PostPosted: Sun Sep 11, 2011 1:56 pm
i am quite shure it is the marelli box it did it again it is temp related
PostPosted: Sun Sep 11, 2011 2:46 pm
there is a thread in the FAQ on repairing the output transitors and there are outfits around that will do it for you
PostPosted: Mon Sep 12, 2011 11:58 am
took it out for a ride saturday it ran perfect for about 10 to 15 min,s.
i was going 50mph down the road and bike just stopped.coasted over to the side of the road
engine dead. waited 5 min,s bike would start & limped it home a 2500rpm. let it cool off for an hour runs perfect. i am convinced the spark is the problem. :banghead: i ordered a new marelli digiplex box today
PostPosted: Mon Sep 12, 2011 12:36 pm
I had a similar situation a while back on my 906. I would run fine for a while then out of the blue start missing gradually getting worse to the point it would die.Other times I would just get a hiccup when cruising around 60mph. Sometimes it would start right back up sometimes it was stone dead,others just spit and cough. In the end it turned out to be the connector on the base of the ignition switch. The tabs that hold the connector in place being 20+ years old just couldn't keep up with the road vibrations. I replaced every connector and used a wire tie to keep the tabs in their proper place. Been fine ever since :thumbup:
May not be your issue,but a good place to start while waiting for your new module
