ducatipaso.org • View topic - Clunck-oilspill-engine-no-more
It is currently Sat Jun 20, 2026 10:22 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: Clunck-oilspill-engine-no-more
PostPosted: Tue Sep 13, 2011 7:33 pm
Just want to share this with all of you.
Today I was riding through town when suddenly CLUNCK the engine seized at once. I stopped in the street and the oil was dripping on the pavement.
I think I need some time in the shed...
Cheers Joep
 Post subject: Re: Clunck-oilspill-engine-no-more
PostPosted: Tue Sep 13, 2011 7:50 pm
The infamous crank plug issue :dunno: :,(
PostPosted: Wed Sep 14, 2011 12:56 pm
That sounds bad!!
Where was the oil coming from??
PostPosted: Thu Sep 15, 2011 3:16 am
Joep,
was that your 900 motor? does that mean you have a spare 750 motor?
Indeed, I see some shed time in your future. Bummer dude.
Phil
PostPosted: Thu Sep 15, 2011 6:39 am
SO sad...
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Thu Sep 15, 2011 6:33 pm
Thanks for the replies.
Yeah its the 900 engine. Did not have enough time to check what has happend. Still have the 750 which is in bad shape. But not as bad as the 900 :lol:
Thanks again
PostPosted: Fri Sep 16, 2011 9:37 pm
damm!! joep, das balen.
good luck getting it on the road again!
ducati pantah 600 racer 1980
ducati 750 sport tricolore 1990
ducati 750 sport racer 1988
ducati 750 sport parts bike 1990
ducati 1100 evo hypermotard
PostPosted: Sun Sep 18, 2011 7:00 pm
Found out that the alternator cover was cracked. Suspect a run loose flywheel. It was me who torqued up and loctited the nut the last time....
Normally I do not use a puller to get the cover off. This time I will need one but I first have to make one.
Speak to you soon.
Joep
PostPosted: Sun Sep 18, 2011 8:56 pm
Jeez dude,wtf :lol: :lol: :lol: :lol:
PostPosted: Mon Sep 19, 2011 8:12 pm
It may be recoverable!!
PostPosted: Sun Sep 25, 2011 6:16 pm
OK,
Got the cover off and found a crack alternator rotor, which had seized the engine. How can this happen?
Cheers Joep
PostPosted: Thu Nov 24, 2011 8:05 pm
hej Joep, whats up whit the bike / engine, any news?
gr.
PostPosted: Fri Nov 25, 2011 11:37 am
Not much,
Like I said: cracked rotor which dislocated the altenator and that cracked the side cover. I do not know why the rotor got cracked in the first place but I did put it on so I think I have only myself to blame....
I currently looking at the orignal 750s engine the bike came with. I'm planning to overhaul it. So far I found 750 ss (low compression) pistons inside and what I believe to much play on the conrod big ends.
I'm also moving from one shed to an other. That doesn't help in the progress.
Thanks for asking
Cheers Joep
PostPosted: Fri Nov 25, 2011 12:00 pm
if you hit a stator rotor with anything,its history. Can't drop them either.
Rare earth magnets are very easy to fracture. There are 14 rare earth magnets encased in lightweight aluminium making up the rotor. once any of the 14 are cracked its just a matter of time till the whole assembly comes apart. My guess is when it siezed inside the stator you probably twisted the crankshaft also at the very least.
On a positive note they does seem to be a fair supply of engines around most of the time
PostPosted: Fri Nov 25, 2011 5:40 pm
most likely reason is overtightening the nut.
It`s essential it`s torqued correctly.
