ducatipaso.org • View topic - strange clutch noise
It is currently Mon Mar 09, 2026 3:07 pm
 Post subject: strange clutch noise
PostPosted: Wed Sep 14, 2011 6:02 pm
hello there,
for about one week there is strange noise coming from the clutch gasket.
(and I am not saying about that lovely dry clutch sound :) )
at the beginning, noise appears when the clutch handler was not pressed
(and when I pressed clutch handler - noise dissapeared)
but now it appears quite often.
I took off clutch gasket, and the center "screw" is easly rotating.
(by the "screw" I mean the thing selected in red ;)
http://imageshack.us/photo/my-images/11/clutcht.png/
(its not my clutch, just found a photo)
as far as I rememer it shouldnt rotate?
(it can be easly rotate by hand, and gives that bad noise)
some grease should be enought or should it be replaced?
regards
Greg
 Post subject: Re: strange clutch noise
PostPosted: Wed Sep 14, 2011 6:26 pm
That`s not a Paso engine/clutch. That looks like the pressure plate from a SS/Monster engine with the clutch piston on the left engine side. In that case the marked part has to rotate as that`s the bearing.
If you have an original Paso motor/clutch the center part is fix with the pressure plate and does not turn. For that there is the bearing in the clutch piston/cover.
PostPosted: Wed Sep 14, 2011 6:55 pm
thank G for fast answer,
yes, I think that I have oryginal clutch
(but I`ll take a photo tomorrow to make sure)
so it means that marked part shouldnt rotate, so...
how to repear it? ;)
PostPosted: Wed Sep 14, 2011 7:07 pm
Undo your 6 pressure plate bolts (a little bit each at a time),the plate and pin will just lift out,if you turn it over you should see that the 2 or three little spot welds have broken.They don't weld them fully to avoid buckling the plate.grind them off and get them re done. J
PostPosted: Tue Sep 27, 2011 10:07 am
I recently solved a screeching sound from the clutch by cleaning and lubricating the bearing in the cover with a bit of WD40 and a bit of grease (not too much!!). By the way: this is how a PASO clutch looks and sounds like:
(i made a little video of my clutch )
Kawasaki Z700 1987, Kawasaki ZL1000 1990, Ducati PASO 750 1990,
Ducati 900ss 1993, Ducati Paso 906 1990
Users browsing this forum: No registered users and 42 guests
