ducatipaso.org • View topic - Oil Pressure Sensor Replacement?
It is currently Mon Mar 02, 2026 1:47 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: Oil Pressure Sensor Replacement?
PostPosted: Thu Sep 29, 2011 8:09 pm
Googled the 69921511A p/n and it comes up here: http://www.store.commoto.com/product_in ... s_id=71923
looks like we can get it for all our bikes?
doug
1992 907ie #1473 Nero SOLD
PostPosted: Fri Sep 30, 2011 9:38 pm
Land Rover discovery TDI 300 is also a direct swap.Your local auto parts store should have a aftermarket catalogue full of senders and their switching modes and thread pitches,I just went down the list until I found the correct mode and pitch with a price that matched my wallet. :mrgreen: :mrgreen: J
PostPosted: Sat Oct 01, 2011 2:51 am
Mine is off a VW golf ..... I think . Like Jayh I wandered down to the local parts guy ( Jim @ Allparts ), perused the catalogue , 10mm taper thread , nc ,6.3mm spade & 7 lb crack.....mmm a Vee Dub huh. There were 1/2 a dozen that would have done if I could be bothered changing the terminal on the harness to suit , and I figured that the operating pressure wasnt vital as long as it was ballpark , I mean if you are supposed to have 60 psi it doesn't matter if the red light is telling you that you have less than 7 psi or less than 4 psi , either way your history.
If I set the idle to low the oil pressure light on my guzzi winks at me like a homo in the toilets ... probly harmless enough but unnerving all the same ( I can get it to idle at 4 -500 rpm ) and anyhow its not 1/2 as excitable as the charge light which blazes away at anything below 1700rpm . :shock: fuck :!: I hope I havnt got them mixed up
I dont do italian :lol: :lol:
gen ... charge light , folle.... blinkers , luci ... neutral and olio for oil pressure..........I think :)
PostPosted: Sat Oct 01, 2011 6:38 am
Gabriel
Paso 750
Elefant 750 Monofaro
Elefant 900 Monobraccio
Elefant 750 pure off
Indiana 650
PostPosted: Sun Oct 02, 2011 12:46 am
