ducatipaso.org • View topic - JE psitons quality
It is currently Sun Apr 26, 2026 12:55 pm
 Post subject: JE psitons quality
PostPosted: Mon Oct 17, 2011 9:46 pm
has anyone experience with JE pistons about weight, durability, etc.
I saw a set offered, but don't know them.
Any input is welcome.
Bertus
 Post subject: Re: JE psitons quality
PostPosted: Mon Oct 17, 2011 11:28 pm
They are very good pistons. Lots of racers and others use them. I think they are all forged.
PostPosted: Tue Oct 18, 2011 12:51 am
A little lighter than standard, like 25 gram each or so.
Have no problems w them, have them in both my bikes.
PostPosted: Tue Oct 18, 2011 7:51 am
Jon and Gert,
thank you for your comments. :D
Gert, do you know by chance how heavy the original pistons are? something about 500 gram?
Bertus
PostPosted: Tue Oct 18, 2011 2:09 pm
IIRC, JE 435g & OEM 460.
If buying a used set and want fresh rings,
do buy from US, veeery much cheaper!
http://www.ca-cycleworks.com/ has them f e.
PostPosted: Thu Oct 27, 2011 2:14 am
A word of warning about used pistons, Ducati's have a tight tolerance on the piston to wall clearance. They classified pistons as A or B fit. I bought a used set only to find they had too much clearance. They also wear in the ring grooves. I looked into stock bore J&E pistons, but no gaurantee that the Nikasil plating would not have to be redone for fit. I ended up buying J&E ST-2 pistons, sending the cylinders and pistons to Millenium for a bore and Nikasel plating, and shimming the 11:1 pistons to yield 10:25 compression. I use a FBF chip and 89 octane gas, the motor runs strong and gives me a consistent 50 mpg. I highly recommend J&E and CA cycleworks :thumbup:
