ducatipaso.org • View topic - Venhill Install
It is currently Tue Sep 30, 2025 4:34 pm
 Post subject: Venhill Install
PostPosted: Sat Nov 19, 2011 5:49 pm
The original
The kit
The install
reused the brake switch and removed the caliper to hang it high to ease the bleeding hassle..........All fittings are torqued to 18ft-lbs(25Nm) Dot 4 fluid
more to come.........
 Post subject: Re: Venhill Install
PostPosted: Sat Nov 19, 2011 6:07 pm
I wonder why one end isn`t by 90° turned or can you do that ? If both are the same the line has to be warped which is not ideal.
PostPosted: Sat Nov 19, 2011 6:14 pm
you can turn them any way you like as they are a bolt on part
Next pictures will get more detailed on the kit
and the dimension Joking needs :thumbup:
PostPosted: Sat Nov 19, 2011 6:43 pm
Cool! I am looking forward to that :thumbup:
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Sat Nov 19, 2011 7:04 pm
I too ordered a hose from Venhill. When I get it, I will also post pictures of the my install, but on the Sport page. I like the fact that you can rotate the fittings on the Venhill stuff. I have a box of hoses, but many I can't use because the heads are in the wrong orientation.
PostPosted: Sat Nov 19, 2011 7:35 pm
Got a complete set,rear front and clutch
I believe the clutch line is the same on the 906 and 907
PostPosted: Mon Nov 21, 2011 10:01 pm
Are you sure?
I guess the clutch line is too long for the 907.
The 906 one has to come to the clutch cover.
PostPosted: Tue Nov 22, 2011 10:13 am
Length could be different but the fittings are the same, clutch line was a custom fit now that you mention it :beer: :beer:
PostPosted: Tue Nov 22, 2011 11:14 am
PostPosted: Thu Nov 24, 2011 6:57 pm
The Venhill Clutch Line Custom Kit Thanks to Chris at Venhill USA :beer: :beer: :beer:
The old line at the master
The old line at the cover
Cheapo bleed setup..5 dollar flavor injector of 1 ounce capacity, You could most likely find one for a dollar at your
local dollar store :smoke: Please note Jonboy Slocums coffee can/vacuum cleaner method works just as well.....
Atta boy Jon :lol: Hope you are home with your family today :thumbup:
Took very little to bleed it completely...3/4 of an ounce of air and two fills on the master and ready to go :thumbup:
Well except my regulator jobs needs to be completed :roll:
Up next the new front brake line setup :beer: :beer: and the pictures I forgot of the new clutch line fittings :mrgreen: :mrgreen: :mrgreen:
My apologies to Chris, so sorry and Happy Thanks Giving to all who celebrate this day :choo:
The forgotten photos of the new clutch line
PostPosted: Sat Dec 03, 2011 4:04 pm
For the brake lines there are several options. I went for the two line direct eliminating the equilizer/brake pressure switch. This requires a new option for the brake light switch of which there are two. One is a two line banjo bolt with a pressure switch at the master or the one I most likely will do is to install the Brembo Microswitch on the lever ala the 907ie. I got both of these from Bevel Heaven :truck:
The old lines removed: 21 years old well past time to go :phone:
the new lines
One comment in passing, the banjo bolt supplied with the brakeline kit was about 4mm too long.
In the interest of time I ground it down, I have no doubt Chris would have happily swapped me with the correct bolt if I asked . :thumbup: I also removed the front fender and brace to make the installation at the calipers easier. It's a tight fit otherwise :beer: :beer:
I will also remove the calipers and hang them higher than the master to make bleeding easier :choo:
Users browsing this forum: No registered users and 47 guests
