ducatipaso.org • View topic - ESR515
It is currently Wed Oct 01, 2025 2:16 am
 Post subject: ESR515
PostPosted: Fri Nov 25, 2011 9:22 pm
Anyone done one of these ?
 Post subject: Re: ESR515
PostPosted: Fri Nov 25, 2011 10:09 pm
a very clear headline, everyone will know what this is about :truck:
Isn´t the Electrosport ESR515 just the same as the Electrex RR51 ? The instructions are the same.
http://www.electrosport.com/technical-r ... ctions.pdf
http://www.electrexworld.co.uk/pdfs/RR51-ducati.pdf
PostPosted: Sat Nov 26, 2011 4:33 am
no,already tried that
PostPosted: Sat Nov 26, 2011 5:53 am
Looks to be the most recent offering by ElectroSport
http://www.electrosport.com/street-bike ... rectifiers
Cant' quite tell what the difference is, except the connectors. Same basic unit as best I can tell.
PostPosted: Sat Nov 26, 2011 9:08 am
About connectors, I can tell the RR51 needs some little mod to fit on 907 electrics.
Does that ESR515 require less mods to fit on?
PostPosted: Sat Nov 26, 2011 1:05 pm
I have tried contacting Electrosport directly but due to the holiday I have as yet not recieved an answer.
Everything on the website says it is a direct replacement for the OEM. They even sell a connector kit that dupes the OEM. I tried a wire for wire hookup and also tried the rr51/esr51 hookup with no luck so far. I thought I remembered someone else had run across this before
It is said to fit a range of Ducati's from a 78 Pantah to a 98 ST2 and a range of Guzzis.
Anyone recognize the connector style, maybe I can sort it out that way........My Fluke unfortunately has blown a fuse which I won't be able to get till Monday at the earliest so I'm kinda stuck. I suppose as the clock in the 906 has gone bad again it could be the issue,maybe I'll remove it and see what happens.
BTW, I'm fitting it to the 906 with a 3 wire single phase stator
The 906 went belly up on me on a ride 2 weekends ago. Stopped to get some fuel and when I restarted the charge light came on for about 10 minutes. About an hour later we made a stop at Washingtons crossing, where the Norton Gathering is held and I had to bump start it. Half hour later she spit flames and died as the ignition system went belly up due to the dead battery :lol: :lol: :dunno:
PostPosted: Sat Nov 26, 2011 1:30 pm
so I understand you already have one. Then what`s the question ?
PostPosted: Sat Nov 26, 2011 1:34 pm
PostPosted: Sat Nov 26, 2011 1:43 pm
I`d say as the text mentions the ESR510 and 515 are internally indentical they just have differing wire colours (for whatever reason they did that)
My understanding:
black: ground
white: dashboard warning light (which would also explain the shape of the connector housing to prevent a short)
red: 12V
yellow: alternator
just like in the manual for the 510 with the difference that green is now black. If the right alternator connection is setup 1 or 2 will have to be tried. You should still have an analog volt meter :)
PostPosted: Sat Nov 26, 2011 1:49 pm
PostPosted: Sat Nov 26, 2011 7:31 pm
btw. on the Electrex website it says:
NOTE: for models with 2x YELLOW and 1x RED generator wires, please use type RR51, with both yellow generator wires connected together as 1 phase wire to the RR51, and the red generator wire as the second phase wire to the RR51.
which corresponds to the second wiring setup of the instructions.
(red wire of course meaning the wire coming from the alternator not the one on your reg/rect.)
PostPosted: Sat Nov 26, 2011 9:10 pm
Yes G, I know, As I said that was my second hookup
Something else is up,guess I will have to wait till Monday unless I can it figure out :thumbup:
PostPosted: Mon Nov 28, 2011 6:00 am
Run over to Harbor Fright, they have meters for about 69 cents!! Sometimes free if you use the mens room :-)
PostPosted: Mon Nov 28, 2011 11:18 pm
fluke is fixed diodes check good,stator checks good'
soon as I get these bandages off will ,start looking for broken wire in the harness, must be a splice in there between the stator and the reg connector
PostPosted: Tue Dec 20, 2011 3:25 pm
Still not sorted out.
I did finally hear from Electrosport and they have giving me a few things to try before I pull the Stator out.
This one's got me scratchin my head :wacko:
Ducati electrics, What were they thinking ?
