ducatipaso.org • View topic - New here
It is currently Thu Apr 30, 2026 11:26 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: New here
PostPosted: Tue Dec 13, 2011 10:50 am
I'd just like to introduce myself to the forum as a new member. I have recently, 2 weeks ago, bought a 907ie to accompany my '03 ST4s ABS that I've had since 2005. The 907 was registered in the UK in March 1994 and is one of the last, with Goldline brakes. It's red and is completely standard and original. I've been into Ducatis since the early seventies and have plenty experience with bevel twins and singles and belt twins, 2V and 4V. Electrics are my speciality but I'm equally at home with any mechanicing. I'm looking forward to getting out on the 907 in the coming year when the weather improves.
 Post subject: Re: New here
PostPosted: Tue Dec 13, 2011 10:57 am
Wow. Another nice bike. :thumbup:
An me? I am spending loads of time & money, trying to bring mine into an equal condition. :?
As you are an electrics specialist, can you tell me where to get the dash-connectors from? :wacko:
Johannes
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Tue Dec 13, 2011 11:04 am
Can you give us the frame number? Currently, mine is the last known, i think...
86` Ducati 750 Paso
PostPosted: Tue Dec 13, 2011 12:01 pm
JoKing
Which ones you need? I have some although they are not new on my donor 906
PostPosted: Tue Dec 13, 2011 1:24 pm
The ones that connect to the rear of the dash, because i am building a mixed 907/ST3 Harness....
86` Ducati 750 Paso
PostPosted: Tue Dec 13, 2011 2:28 pm
PostPosted: Tue Dec 13, 2011 3:06 pm
have all 3
PostPosted: Tue Dec 13, 2011 3:10 pm
higgy, Johannes, some others and I are looking for new ones to build a new wiring harness. The plastic connectors can be resued that`s not the problem but the crimped contacts need to be replaced. Finding those is not so easy.
PostPosted: Tue Dec 13, 2011 3:13 pm
86` Ducati 750 Paso
PostPosted: Tue Dec 13, 2011 3:24 pm
I can send them out. I can also cut them as long as you need except for one that is already cut short.
I'll get you a pic and pm it to you ,we'll work it out
PostPosted: Tue Dec 13, 2011 3:51 pm
Pm on the way
PostPosted: Tue Dec 13, 2011 4:21 pm
Most are similar to Delphi terminals,I have been trying to figure out exactly who was sourced for the original terminals but yes G you are correct in that they seem to be hard to find and the crimpers needed are also not cheap. Crimpers are from time to time found on ebay for much less than new.
New crimpers are typically in the 100 to 300usd range, ebay 25 to 35.
Delphi does have a catalog you can download and I am in the middle of going thru it now,400+ pages so it will take a while.
Both of you being in Europe might be able to find out who Fiat uses to source their terminals,
Fiat is just now coming back to the US so info is sketchy at best.
I did find a suitable connector and terminals for the regulator from Electrosport The kit was 6 bucks and came with the connector and terminals,nice plated terminals and the connector includes a locking tab
BTW the terminals for the dash are side plane type,double side plane I think
One possibility is an AF Female Terminal UNsealed #12131448 from Delphi
PostPosted: Tue Dec 13, 2011 11:04 pm
higgy, those are not the ones. Check the terminals. They look somewhat like this
PostPosted: Wed Dec 14, 2011 12:06 am
Very clean bike, congrats!
Can you post a close up pic of the top case mount, near rear pegs?
PostPosted: Wed Dec 14, 2011 2:13 am
Hi Derek, nice looking 907!
The standard pipes do look good!
How many km`s?
Is that a battery breather hose attached to the swing arm?
I eneded up buying a deka sealed battery to get rid of any battery acid problems.
