| It is currently Mon Mar 02, 2026 3:18 am |
Page 2 of 3 |
[ 36 posts ] | Go to page Previous 1, 2, 3 Next |
| Author | Message | ||||
| RADDUCK |
Joined: Sat Jul 07, 2007 12:00 am Posts: 51 Location: San Francisco, CA model: 750 Paso year: 1987 |
| Top | |||||
| paso750 |
Joined: Sun Jul 18, 2004 12:00 am Posts: 5494 Location: southern Germany model: 750 Paso year: 1987 |
| Top | ||||||
| Mc tool |
Joined: Wed Dec 05, 2007 12:35 am Posts: 1793 Location: Newzealand model: 906 Paso year: 1990 |
| Top | ||||||
| RADDUCK |
| Top | |||||
| paso750 |
| Top | ||||||
| RADDUCK |
| Top | |||||
| RADDUCK |
| Top | |||||
| Mc tool |
| Top | ||||||
| paso750 |
| Top | ||||||
| pepe rull |
Joined: Mon Mar 18, 2013 3:55 pm Posts: 14 Location: ALMERIA,ANDALUCIA,SPAIN model: 750 Paso year: 1988 |
| Top | ||||
| paso750 |
| Top | ||||||
| pepe rull |
| Top | ||||
| paso750 |
| Top | ||||||
| pepe rull |
| Top | ||||
| pepe rull |
| Top | ||||
Page 2 of 3 |
Users browsing this forum: No registered users and 4 guests |
| You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum |
, although I would have to say making something like that isnt easy. I have been looking at some of the larger tupperware / click clack type containers to see if one couldnt be modified/adapted , but I dunno if the plastic would be fuel proof
and didn't realize it until I tried to fire it up for a test ride. Lots of cranking, no love. When it did fire up it wouldn't idle, lots of popping and backfiring. Went for a short test ride anyways and it ran terrible. Nice and smooth at about 4K but definitely lean right off idle, bucking and hesitation. Weaker WOT than with the stock jetting. Parked it for the night. Next morning turned the mixture screws to 3.5 turns out and it was a whole different machine, idles again starts w/o choke. Still slight hesitation off idle when cold and WOT not as strong as previously. Pulled carbs and installed larger stage 2 YJ128 main jets, remembered to hook up the choke this time. Best its ever run. Strong and beefy, WOT stronger than with stock jetting, smoother running characteristics throughout the entire range. Easily pull away from a stoplight just above idle even with a passenger. Still get some popping on closed throttle when decellerating. Turned the mixture screws to 4 turns out definite improvment, still the occasional pop. Spoke to Owner at DesMoto, a great Ducati only tuning shop in San Francisco, (Admired a beautiful Paul Smart 1000). Apparently 5 turns is the maximum range for the mixture screws before they can vibrate and fall out. I'm at 4 turns now and may try to go a little richer yet. If no improvment I will raise the needles 1 notch next time I have the panels off and go back to 3.5. All in all a much better running machine. Not sure I'm in love with the honk from the pod filters. Deeper throatier sound with the rat-trap air box. Thanks again for the hook up with the Dynojet kit Gerhard. Happy New Year!
, but if your interested I could have a look at these jets and let you know what I have
