ducatipaso.org • View topic - Another 1990 Sport
It is currently Mon Sep 29, 2025 6:28 am
 Post subject: Another 1990 Sport
PostPosted: Sat Jan 07, 2012 8:14 am
Howdy,
I know it's wrong to love these bikes, but I do. I was sweet on them when they hit the market as I was a big fan of the 750f1 back then. I rode with some folks at the time who had pasos and even 888/851 models, but at the time it was beyond my means so I could only dream.
Not sure why I've waited so long to locate one and slide it into the garage, but finally I have. Sold my 749 a while back, and I've missed my weekly(at least) dose of ducati magic.
It's a 90 sport - straight, clean original with some sweet sounding feracci pipes. Dellorto conversion was done before I found it along with a few other small mods. Seems to be crack-free and overall in solid mechanical shape. I'm servicing it now.
Also, I'll be preparing for regular street and occasional track duty. Most importantly I'm collecting what I can for a 17" conversion. Picked up a set of wheels off a monster - 3.5 front, 4.5 rear. Be stripping those down for powdercoat tomorrow. Shiny black I think.
As for the brake set up front / rear I'm still trying to fully understand my options. I would prefer to keep the same front rotor size along with stock caliper location, but not sure if this is even possible. As for the rear, the rotor from the Monster is quite a bit smaller than the stock Duc rotor. Again, in an ideal world I'd find a larger rear rotor for that Monster wheel so I don't have to move / swap the rear caliper. I guess I also need to find a reliable source for front and rear axle spacers.
I will welcome any personal experience as to the best source(s) for the rest of the 17" conversion bits I need can be found.
Once I get the wheels all set, I think I'll try to locate a slightly longer shock then start putting some miles on it!
Still trying to figure out how to post photos, but I'll get it shortly and follow up...
Ride Safe, Ride Often
hdh
 Post subject: Re: Another 1990 Sport
PostPosted: Sat Jan 07, 2012 8:27 am
http://s1187.photobucket.com/albums/z39 ... /DucSport/
perhaps this link will work if you'd like to take a look at my bike and bits...
PostPosted: Sat Jan 07, 2012 12:43 pm
Hi & welcome,
as for the brakes there are no bigger ones than the 280mm for the original 16" wheels unless you make something. There are not many other brake discs that have such a big inner diameter so alternatives you possibly could adapt with a custom spacer are limited.
In case you swap for 4 piston Brembo calipers with 40mm mounting hole distance you could go for 300mm discs on your 17" wheels. The drawings for the caliper mounting adapters can be found in the download thread on top of the P750 forum. These adapters fit for 280mm discs and if you turn them upside down for 300mm. That would be one option.
For posting photos just go into your photobucket account, checkmark all pictures you want to post and then scroll to the bottom to the drop down "choose action" menu and select "generate link codes ...". Click in the field that says "full size" (those are the links starting with [img]...) and paste the links in your editing window via right mouse click and "paste". That`s it.
PostPosted: Sat Jan 07, 2012 4:32 pm
Thanks, yep, saw the bracket drawings and examples. Sounds like I'll be forced to go that route - is anyone making these around the SF bay area, or is it a full DIY proposition?
The styling of the brackets seems a bit clunky for the bike, but I can live with it to keep the stock fork.
As for photobucket, I'm still trying to follow all the instructions and figure it out. Could you tell me under which tab I could find the option you're suggesting on a drop down menu? I've searched around in all the Album tabs I can find and nowhere does the option you suggest appear yet. I'm using photobucket for the first time though, so I'll keep working with it today and eventually I'll get it.
After posting this last night, I woke up wanting to go for a little ride!
Thanks for any help!
PostPosted: Sat Jan 07, 2012 4:38 pm
Just log in and scroll to very bottom of that page and you`ll find the "choose action" tab. (of course that only works if you checkmarked some pictures).
The aftermarket brake caliper adapters are the same for some Guzzi or Laverda. There are some shops that have them. Would have to check.
PostPosted: Sat Jan 07, 2012 4:41 pm
Thanks!
PostPosted: Sat Jan 07, 2012 4:46 pm
http://www.ebay.com/itm/40mm-Billet-Bra ... 3f06b90f36
https://shop.bevelheaven.com/detail.aspx?ID=925
you may get them cheaper somewhere else or if you get them made. It doesn`t say for which brake disc diameter the first adapters are 280/300mm or 300/320mm.
Would you add your location to your profile ?
PostPosted: Sat Jan 07, 2012 10:38 pm
Here you go mate.
Put your mouse over the photo you wnt to copy.4 options will come up.Go down to IMG code and click on it.It will turn to copied.Go to your message box and left click then past.Done.
Nice bike too.I look forward to seeing your results with the wheels.
A2
PostPosted: Sun Jan 08, 2012 6:33 am
https://shop.bevelheaven.com/detail.aspx?ID=1430
I'm not totally familiar with all the nuances of the front ends on these bikes, but wouldn't these rotors bolt up to the Monster front wheel and also work with the stock calipers in the stock position?
:thumbup: I appreciate the help with photo posting. Still can't find the location of the photobucket aspects you mention, but I do like the copy/paste short cut.
I'm in Santa Cruz, CA - added my location to my profile - thanks for reminding me as I missed it during my profile setup. Need to get on my work computer to create a proper avatar.
Ordered new belts, filter and olio today - need to swap/ change for safety. Motor sounds really really good though as is.
Lastly, I was wrong - actually hadn't looked if you can believe it - my bike has Mikuni, not Dellorto carbs as I thought I was told from PO. Warm up circuit seems a bit funky with some back firing and missing until its really warm once off the full choke. Any pointers regarding tuning on these or some place to point me to learn?
Thanks!
PostPosted: Sun Jan 08, 2012 7:04 am
PostPosted: Sun Jan 08, 2012 7:23 am
Nice tutorial. Love my Rizoma tail turn sigs. Now, to find matching fronts...
Thanks!
PostPosted: Sun Jan 08, 2012 11:23 am
