ducatipaso.org • View topic - What Oil?
It is currently Sun Sep 28, 2025 11:04 am
 Post subject: What Oil?
PostPosted: Mon Jan 09, 2012 7:56 pm
Hi Guys
sure this has been covered a few times before but.......
What oil do you use? Not so much the make but what viscosity? Tell you why I ask:
I was at one of our local race meetings and a some guy who claimed to be a "Ducati Mechanic" asked what oil i was using - told him Castrol R4 Superbike 5W-40. Big fowns and shakes of the head "not right you should use at least 20W-60" Really? He then went on further to say it will cause most problems with the operation of the clutch..................that's when i stopped listening.
I have been using this oil for over a year now and have done 7 race meetings and it been all good. Is 5w-40 too thin for our motors?
Clive
 Post subject: Re: What Oil?
PostPosted: Mon Jan 09, 2012 8:04 pm
0w-40 here,full synthetic
I don't think I'd use 5w-40
PostPosted: Mon Jan 09, 2012 10:00 pm
I`m running 20W-50 as recommended in the user manual. (Used Castol mineral in the past now AGIP synthetic)
PostPosted: Mon Jan 09, 2012 11:38 pm
PostPosted: Tue Jan 10, 2012 12:14 am
G - hence why i stopped listening to the guy...........
I had to show him the holes in my clutch cover to prove it's a dry clutch!!!
Higgy why 0W and why not specifically 5W? Just means at winter tempertures 0 is slighty thinner than 5. I was more concerned about the 40 but having done a fair bit of research now a 10W40 semi or fully synthetic is recommneded by most for our engine.
Clive
PostPosted: Tue Jan 10, 2012 1:18 am
0w is completely different than 5w
0w dies not change viscosity regardless of temp
PostPosted: Tue Jan 10, 2012 4:25 am
I've run 20/50 mineral in all my bikes ( except the bevel and that could change soon as well) and have never had a problem.I'll be putting the same in the Sport when it's time.
A2
PostPosted: Tue Jan 10, 2012 8:15 am
Bevel: HD50 Oil
907 w ST3 engine: 10W50
The lower number can roughly be seen as the value for the viscosity when cold-starting the engine.
The higher number shows abstract the temperature where the critical viscosity is reached.
My Bevel is nearly never "cold started" so it gets the HD50...
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
