It is currently Sat Jun 13, 2026 2:55 pm
[ 8 posts ] |
| Author |
Mustang505
Post subject: What Oil? Posted: Mon Jan 09, 2012 7:56 pm |
Joined: Wed Jan 28, 2009 9:27 pm Posts: 134 Location: Auckland, New Zealand
Hi Guys sure this has been covered a few times before but....... What oil do you use? Not so much the make but what viscosity? Tell you why I ask:
I was at one of our local race meetings and a some guy who claimed to be a "Ducati Mechanic" asked what oil i was using - told him Castrol R4 Superbike 5W-40. Big fowns and shakes of the head "not right you should use at least 20W-60" Really? He then went on further to say it will cause most problems with the operation of the clutch..................that's when i stopped listening.
I have been using this oil for over a year now and have done 7 race meetings and it been all good. Is 5w-40 too thin for our motors?
_________________ Cheers Clive
| Top |
Post subject: Re: What Oil? Posted: Mon Jan 09, 2012 8:04 pm |
| paso grand pooh-bah |
0w-40 here,full synthetic
I don't think I'd use 5w-40
| Top |
Post subject: Re: What Oil? Posted: Mon Jan 09, 2012 10:00 pm |
I`m running 20W-50 as recommended in the user manual. (Used Castol mineral in the past now AGIP synthetic)
| Top |
Mustang505
Post subject: Re: What Oil? Posted: Tue Jan 10, 2012 12:14 am |
G - hence why i stopped listening to the guy........... I had to show him the holes in my clutch cover to prove it's a dry clutch!!!
Higgy why 0W and why not specifically 5W? Just means at winter tempertures 0 is slighty thinner than 5. I was more concerned about the 40 but having done a fair bit of research now a 10W40 semi or fully synthetic is recommneded by most for our engine.
| Top |
Post subject: Re: What Oil? Posted: Tue Jan 10, 2012 1:18 am |
0w is completely different than 5w
0w dies not change viscosity regardless of temp
| Top |
Andrew2
Post subject: Re: What Oil? Posted: Tue Jan 10, 2012 4:25 am |
Joined: Thu Oct 27, 2011 7:47 am Posts: 497 Location: Wollongong,Australia
I've run 20/50 mineral in all my bikes ( except the bevel and that could change soon as well) and have never had a problem.I'll be putting the same in the Sport when it's time.
Cheers A2
| Top |
JoKing
Post subject: Re: What Oil? Posted: Tue Jan 10, 2012 8:15 am |
Joined: Mon Jun 20, 2005 12:00 am Posts: 362 Location: Northern Germany / Kiel
Bevel: HD50 Oil 907 w ST3 engine: 10W50
The lower number can roughly be seen as the value for the viscosity when cold-starting the engine. The higher number shows abstract the temperature where the critical viscosity is reached. My Bevel is nearly never "cold started" so it gets the HD50...
_________________ 92` Ducati 907 i.e. - ST3-Conversion --> Burned down with my barn 78` Ducati 900 SS - Bevel --> Sved her by risking my life 90` Cagiva Freccia C12R - Paso`s smaller sister --> Burned down with my barn 86` Ducati 750 Paso 96` Cagiva 750 AC Elefant
| Top |
[ 8 posts ] |
Users browsing this forum: No registered users and 39 guests |
