ducatipaso.org • View topic - ST 2 CAMS???
It is currently Fri Apr 24, 2026 3:54 pm
 Post subject: ST 2 CAMS???
PostPosted: Mon Feb 20, 2012 7:27 am
Does anybody know if st2 cams fit in 907?if so any mods required,any gains
to be had? :dunno: Just pulled heads off to fit mbp collets :thumbup: ,ordered
ohlins shock :choo: fitted braided lines all round :mrgreen: (thanx mr speigler)
but broke cam belt idler pully bolt :,( ,replacing belts and rollers and dial in cams :wacko: wish me luck :roll: have five weeks to get back together for
trip down west coast nz for best little airshow inthe world :cool:
"keeping the shiney side up"
 Post subject: Re: ST 2 CAMS???
PostPosted: Mon Feb 20, 2012 12:29 pm
They should fit straight in but you will need to completely re-shim all the clearances.
PostPosted: Mon Feb 20, 2012 4:37 pm
And how to connect the tachometer cable? Or do you have a electronic Instrument?
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Tue Feb 21, 2012 10:15 am
PostPosted: Tue Feb 21, 2012 12:55 pm
The hard part will be finding the cams :wacko:
PostPosted: Tue Feb 21, 2012 3:21 pm
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Thu Feb 23, 2012 8:02 pm
I just got a pair for my 907, I can say that they are a perfect fit. The problem is to get them for an acceptable price if you don't want to buy them new for about 700€ (prive in Germany)
Good luck !
Rainer
PostPosted: Fri Mar 09, 2012 3:25 pm
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Fri Mar 09, 2012 7:06 pm
Hi
Why fit ST2 cams?
PostPosted: Fri Mar 09, 2012 7:59 pm
more overlap in the timing = more power on the high end of the rpm band
