ducatipaso.org • View topic - Noisy Paso (help, got 30 days to fix this problem)
It is currently Thu Mar 05, 2026 6:19 am
 Post subject: Noisy Paso (help, got 30 days to fix this problem)
PostPosted: Mon Sep 19, 2005 4:51 pm
PostPosted: Mon Sep 19, 2005 5:54 pm
1988 Paso 750 #753965
1997 Monster 750
PostPosted: Tue Sep 20, 2005 8:43 am
Hello Fry,
You can put in something like this to make it little quiter:
It is a shop in Germany, so it pretty simple to order one.
Make sure it fits your exhaust.
//Anders
PostPosted: Thu Sep 22, 2005 4:58 pm
If the omologation number is not a problem, you can bild a db-killer for your exaust.
Just solder a washer at the end of the pipe, inside the joint with the silencer, in order to reduce the width of the pipe and the gas flowing... After the sound ceck remember to take it away!
Have a nice ride, Nicola
PostPosted: Fri Oct 14, 2005 7:02 pm
Hi Fry, how are you? I had a problem with my loud pipes when I went to ITV (in Spain your M.O.T is our ITV). I machined a pair of aluminium caps with a smaller hole than before, to obstruct the smoke exit partialy. Then I made a little drill hole in the lower part of the exhaust and screw on a little screw to hold in place the caps. This caps restrict the exhaust hole and decrease the noise. When I obtained my ITV document I removed the caps and put them away in the depth of my tool box till next year (when I'll need a new ITV document). :neener:
70 hp. can change the world
Users browsing this forum: No registered users and 31 guests
