ducatipaso.org • View topic - F C R's
It is currently Thu Oct 29, 2026 7:25 pm
 Post subject: F C R's
PostPosted: Sat Mar 24, 2012 1:59 am
Does anyone out there know a bit about these beasts . I just scored a pair of 41's ( actually think Ive been ripped off ). They are split and there is only one accellerator pump ( on the front carb ) and a small hose linking it to the back carb , which sorta makes sense, just that all the pix I have seen show one pump per carb
The other issue is that there seems to be a bit of wear in the throttle shaft/ carb body ... is there a replacable bush in there ? And where do you get o/haul kits (every time I look for any sort of FCR kit I get install kits inc carbs for various bikes ) I need float bowl seals acellerator pump seal and diaphram and the little piece of plastic that sits above the ball valve in the acc pump . These carbs were supposed to be newly overhauled before I got them , but plainly havn't and as Im sick and tired of being fucked about and lied to Ill just sort them myself . If any one can point me to a service manual or even a decent parts diagram I be grateful :)
 Post subject: Re: F C R's
PostPosted: Sat Mar 24, 2012 10:35 am
Can't help you down under but herre are 2 just in case
PostPosted: Sat Mar 24, 2012 10:41 pm
Thanks Higgy . I had found both of those , not sure if it was before or after I posted. I spose I should give em a try before anything else, just gotta sort some filters . Thanks Higgy
PostPosted: Sun Mar 25, 2012 9:18 am
You`ll find my collected info here
http://www.box.com/s/329ay6zzob9yspyisl01
(the link was fixed)
PostPosted: Mon Mar 26, 2012 1:51 am
Yahooo! thanks G, this will keep me busy for a while :) . Bit of a story
I bought them un seen ( and stupidly assumed they would be a joined pair like the mikuni's ) and was told by the seller that he would " re kit/overhaul them , I then waited 7 months for parts to turn up ( usual for him , just doesn't order/ forgets to order then blames suppliers ), finally went in and threw a wobbly and got the carbs , seperate , and obviously never been worked on , but by then I didnt care . And now , lookin at these things Im wondering just how practical they would be on a street bike and Im thinkin I'll just go with the original plan to fit the SS mikunis to the paso , just gotta sort some sort of air filter(s) for them.
Thanks again for the info G , much appreciated :) :) :)
Hamish
PostPosted: Mon Apr 23, 2012 3:54 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Tue Apr 24, 2012 11:46 pm
Thanks for that desmo demon , I have seen that site b4 but I lost it . I will give him a bell and see . Thanks
PostPosted: Wed Apr 25, 2012 1:43 am
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
