ducatipaso.org • View topic - Wanted Piston and cylinder set
It is currently Fri Mar 13, 2026 12:35 am
 Post subject: Wanted Piston and cylinder set
PostPosted: Thu Mar 29, 2012 1:04 am
Hi I just bought a 1990 Ducati paso 750 and on start up it snap a inlet valve. After having been sitting for a couple of years according to the seller it haqd a Ducati rattle. Well i have managed to get a head but the piston is mashed and the bore is marked.
Also I have come accross a dealer that closed his Ducatti sale several years ago and has old stock but needs part numbers as his system has been corrupted. So if anyone has a list of part numbers especially for the piston, ring, cylinder block.
Thank great
Kim Carrera
Ps I am in Queensland
Australia but i buy stuff from all over the world
 Post subject: Re: Wanted Piston and cylinder set
PostPosted: Thu Mar 29, 2012 4:42 am
Ian Gowanloch will have these in stock.
He can catch him on 02 69462626
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
PostPosted: Thu Mar 29, 2012 5:56 am
If you're after part numbers, there is a parts catalog in the 750 thread.
Have a look here: viewtopic.php?f=1&t=1551
PostPosted: Thu Mar 29, 2012 10:17 am
If you do need some Pistons etc then try these if no luck your end - may even be cheaper with the exchange rate/postage aswell, I know they had some on show the other week at a local bike event and they regularly deal with Aussie owners racing 750 Dukes. They should be able to help with part numbers as they seemed very happy to offer advice.
http://www.twowheelclassics.co.uk/
PostPosted: Thu Mar 29, 2012 11:10 am
there are used ones on ebay
http://www.ebay.com/itm/Ducati-Paso-Pan ... 3f11789f5b
http://www.ebay.com/itm/Ducati-88mm-Pis ... 3f0ff6e084
you could also have your cylinders rebored and go 780cc
http://www.ebay.com/itm/Ducati-Piston-K ... 53e504702a
PostPosted: Fri Mar 30, 2012 3:04 am
Thanks for your help
PostPosted: Fri Mar 30, 2012 4:50 am
PostPosted: Mon Apr 09, 2012 2:18 pm
there`s currently a used set on ebay
http://www.ebay.com/itm/Ducati-Pantah-T ... 43aec577e7
The only question is from what model these actually are as the SS has a lower compression than the Paso & Sport.
