It is currently Tue Sep 30, 2025 11:18 am
[ 9 posts ] |
Author |
du907
Post subject: Fuel gauge gone crazy Posted: Sat Jun 02, 2012 1:03 am |
Joined: Fri Jul 08, 2005 12:00 am Posts: 336 Location: Winston-Salem, N.C. USA
Ive been putting my bike back together after a wreck. I noticed when I move the bike around that the fuel gauge needle moves a lot with every move. When the power is off and the tank is full, turn the key on and the needle shoots to the top. I opened the tank and checked for anything floating but all is good. When I move the float up and down the needle responds exactly, no delay. It didn't use to be this way. There should be a damping in the reaction of the needle. It should not respond so quickly. Should there not be a resistor that dampens out the motion of the float? Ideas?
Top |
Bock900r
Post subject: Re: Fuel gauge gone crazy Posted: Sat Jun 02, 2012 9:18 am |
Joined: Tue Sep 07, 2010 1:33 am Posts: 153 Location: Hamburg/Germany Novi/Michigan
It is the same on my 907
It would not work with a Resistor, it would show less fuel but the needle moves like before. A Capacitor would reduce any quick movement
_________________ RĂ¼diger __________ 84 GPZ 900R 84 GPZ 900R 86 GPZ 900R 88 GPZ 900R 888 SP4 907ie Black 907ie Red 907 evo (project) 998 Matrix 998s FE V50 Monza MV Agusta 750 Evo2 ZXR750RR-K ZXR750RR-M
Top |
Fraser
Post subject: Re: Fuel gauge gone crazy Posted: Sun Jun 03, 2012 11:58 pm |
Joined: Tue Jan 17, 2006 12:00 am Posts: 332 Location: Lower Hutt, New Zealand
Guys you miss the point. Check back on the old topics, there are many discussions on the fuel gauge. So, change the mind set and rejoice that you have a very sensitive measuring device that faithfully shows the ever changing fuel level inyour tank. Even over every bump and hill. Cheers,
Fraser
_________________ 750 Paso 1980 Moto Morini 500 Sport 2013 Yamaha MT-01
Top |
du907
Post subject: Re: Fuel gauge gone crazy Posted: Mon Jun 04, 2012 1:52 am |
Fraser, My point in all this is that I don't remember the guage acting this way before my accident. The bike sat for a year before I started riding it again a couple of weeks ago. I just never noticed the needle being so reactive. Don't get me wrong, it would move if I took off real fast, stopped real fast, going up or down hills, just not so fast (the needle movement) and never while just sitting in the driveway and rocking the bike back and forth. But, it does NOW! And with a full tank of gas, start the engine and the needle would come up to full gradually, now it rockets to the top, swish! du907
Top |
Ducolaf
Post subject: Re: Fuel gauge gone crazy Posted: Wed Jun 06, 2012 10:27 am |
Joined: Sun Mar 20, 2011 11:53 am Posts: 140 Location: Eastern Netherlands
The fuel gauge is indeed more stable in the reading on my 907 ie and does not move up and down on every bump or corner. Even the low fuel light is quit dampend in indicating I need to find a fuelingstation.
To my opinion there must be a difference in the measuring or processing of the fuel level in the 907 ie compared to previous models. AS mine is manufactured in 1992, it could be one of the last modifications made much to my liking..
So I think your perception that "something" has changed is indeed correct. Only have no clue what that would be.
_________________ If you realy look you will see that the whole world is Ducati Red. . .
Proud owner of a; - Ducati 907 ie 1992 in red - Ducati 900 SSC Imola 1997 in red - aprilia RST Mille Futura 2001 in infinity blue - Alfa Romeo 159 SW 2007 in Grigrio Stromboli
Top |
ducbertus
Post subject: Re: Fuel gauge gone crazy Posted: Wed Jun 06, 2012 10:09 pm |
paso grand pooh-bah |
Joined: Sun Jan 07, 2007 12:00 am Posts: 531 Location: holland
hi Du907,
as you stated, you're 907 is recovered from a wreck, the bike had probably a severe shock. I don't think this blow damaged your fuel level measurement device inside the tank, but damaged a dampening mechanism in the gauge it selve. if you have access to an other dash with proven functionality you could check this.
Bertus
Top |
Post subject: Re: Fuel gauge gone crazy Posted: Thu Jun 07, 2012 8:02 am |
As you`ve disassembled and rebuilt the complete front end I wonder if the wires to the fuel sender are all connected and connected correctly or if it`s a bad or missing ground connection somewhere.
Top |
Rhino
Post subject: Re: Fuel gauge gone crazy Posted: Sat Jun 09, 2012 7:49 am |
Joined: Wed Oct 20, 2010 5:19 pm Posts: 518 Location: Pembrokeshire
You mean the fuel gauges actually work . . . ????
_________________ Rhino
If God rides a Harley . . . Then the Devil rides a Duke!
Top |
Post subject: Re: Fuel gauge gone crazy Posted: Sun Jun 10, 2012 5:53 am |
Top |
[ 9 posts ] |
Users browsing this forum: No registered users and 49 guests |
