ducatipaso.org • View topic - parts
It is currently Wed Oct 01, 2025 11:58 am
 Post subject: parts
PostPosted: Tue Jun 12, 2012 3:19 pm
I need part # 28740011a or magneti marelli aei 450 b if i cannot find this part will be forced to part out bike :,(
 Post subject: Re: parts
PostPosted: Tue Jun 12, 2012 7:28 pm
Is there a claer name or picture for this?
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Tue Jun 12, 2012 7:32 pm
it is called the ignition module or power module two modules on either side of a heat sink.
PostPosted: Tue Jun 12, 2012 7:34 pm
you have a 907 ie then you can see it located next to the regulator and the ignition relays under the left fairing by the mirror. Und danke auch fur alles jeder kann hier nicht melden.
PostPosted: Tue Jun 12, 2012 9:06 pm
Now I know what yoiu mean. I can't see it, I am working in Serbia for some weeks.
I had seen these on Moto Guzzi Modells. May be they use the same.
I have no spare. good luck
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Tue Jun 12, 2012 10:27 pm
all the Magneti Marelli setup of the 907 (MarelliP7) was used in many other automotive aplications so, maybe, you can find these parts right of the web (or ebay) through a car parts dealers
That part was also used in the 851-888 and I think in the first series of the 916 (Marelli P8)
In the cars, I think it was on the Lancia HF, 4WD, Thema, Fiat Croma, just to name a few.
I will ask a friend who is a Marelli specialist (and vintage car collector :mrgreen: ) hoping he can help
PostPosted: Tue Jun 12, 2012 10:53 pm
On EBAY USA there is ONE attached to a wiring loom
worth giving the guy a call!!!
PostPosted: Thu Jun 14, 2012 3:08 pm
Thank you will try that
PostPosted: Thu Jun 14, 2012 8:46 pm
Gabriel
Paso 750
Elefant 750 Monofaro
Elefant 900 Monobraccio
Elefant 750 pure off
Indiana 650
PostPosted: Wed Jun 20, 2012 10:44 am
It's not that serious...
It would be "nice" to have the original but not absolutely necessary...
the ignitors are a problem to get now but were used on various cars and bikes around the time of production of the 907...so there will be some around - just need to look hard.
Also, they are a common thing...although they LOOK the same they AREN'T the same function...it is possible to use other model ignitors BUT re-wire the connections correctly to match the 907 requirements.
PostPosted: Wed Jun 20, 2012 4:34 pm
Hi Duc24u,
you may contact Carmo at www.carmo.nl
When I'm correct you'll need BB1105(A), BB1135
Personally I've no experience with this company, but would thrust them
Bertus
PostPosted: Thu Jun 21, 2012 10:44 am
http://www.ebay.de/itm/Ducati-Leistungs ... 588ef0f35a
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Thu Jun 21, 2012 12:50 pm
Visited yesterday Ducaparts in Twello the netherlands with parts they have from desmantling damaged or broken bikes. Have a lot of stuff and prices are not like you see on Ebay. K&N filter for the Paso just € 20,- instead of €60 or more.
Perhaps drop them a mail, they speak English and with the partno now what you need. ducaparts at motofun dot nl
Proud owner of a;
- Ducati 907 ie 1992 in red
