ducatipaso.org • View topic - Flat Slide Keihin's
It is currently Sat Apr 18, 2026 11:53 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Flat Slide Keihin's
PostPosted: Tue Aug 07, 2012 9:21 am
model: other
The penny finally dropped on why everytime I ride it, the thing just pops and farts, put the Silentiums? back on that helped some then Uni Filter here made up some pod filters to suit the Keihin's and all fixed, previous owner never rejetted the carbs to suit no airbox and straight through pipes, go figure.
The adapters for the Carbs were not cheap to say the least
This should cheer up Gerhart some :D .
Certainly did me riding it :choo: .
Peter
PostPosted: Tue Aug 07, 2012 12:19 pm
Add a 90 degree boot between the aircleaner and carbs and it will run even better.
PostPosted: Wed Aug 08, 2012 5:06 am
model: other
Thanks Phil, had looked at your setup and was wondering.
When I have the inclination and money, I'll take a stab at rejetting it and getting the Conti's back on.
Peter
PostPosted: Thu Aug 09, 2012 3:23 am
Don't need much money. about $10 each, and now it seems they are even on ebay.
http://www.ebay.com/itm/51mm-2inch-90-D ... 786wt_1165
Cheers, phil
PostPosted: Sun Aug 12, 2012 2:50 am
