ducatipaso.org • View topic - mikuni /webber conversion
It is currently Sun Mar 01, 2026 8:50 am
 Post subject: mikuni /webber conversion
PostPosted: Fri Jul 20, 2012 7:41 am
about to undertake conversion of a set i scored off a monster 600 (02) needles and jets are similar size i`ve read and monster manifolds were included good so far also will get 600s air box hope it fits under tank .will use a carb cleaner spray for good measure .my question is about the wiring connection on side of carb, whats it for , do i need to attach it into the wiring system .i read ( i think it was that poobar chap ) their suggested method for conversion to mikuni`s found it very informative 750 paso 1989 750 monster 1999 suzuki gsxf 750 1999 norton dominator 1956
 Post subject: Re: mikuni /webber conversion
PostPosted: Sat Jul 21, 2012 12:59 am
A picture would help, but my best guess is its a Throttle position sensor.
PostPosted: Sat Aug 11, 2012 5:33 pm
It's carb heat, to prevent icing.
PostPosted: Sat Aug 11, 2012 6:39 pm
I'm not aware of any electrical connection to the Mikunis. They don't have a TPS and the carb heater is from the oil line that attaches to the float bowls as an option.
PostPosted: Sat Aug 11, 2012 8:06 pm
Some Ducati Mikunis came with engine-oil carb heat (girlfriend's 900SS FE) and some came with electrical heating elements under the throttle plate (mine).
PostPosted: Mon Aug 13, 2012 10:16 am
PostPosted: Mon Aug 13, 2012 5:39 pm
And you will need carb heat when it's 40F and foggy or rainy. I once rode 30 miles on the interstate with the throttle stuck open from carb icing, feathering the brakes to control speed. Lost my nerve after a while, hit kill switch and pulled onto shoulder. A minute of non-operation melts the ice.
That was with the Weber. Mikunis do the same until you switch the heat on.
