It is currently Mon Mar 02, 2026 6:36 pm
 Post subject: 906 Paso Starter - UK
PostPosted: Thu Aug 30, 2012 12:59 pm
New starter motor required or equivalent that will fit. Can it be rewound otherwise.
UK West Mids.
Anybody any ideas. In the middle of a rebuild and on a learning curve.
Adrian.
 Post subject: Re: 906 Paso Starter - UK
PostPosted: Thu Aug 30, 2012 1:08 pm
sure it`s not just worn brushes ?
PostPosted: Fri Aug 31, 2012 10:57 am
Dont think so until i get it apart, just seemed to seize up
PostPosted: Fri Aug 31, 2012 4:54 pm
that could theoretically happen if the brushes are so worn the come out of their guides. In that case the windings could get damaged.
http://www.stockers.com/
PostPosted: Fri Aug 31, 2012 5:15 pm
Brushes don't require to remove the starter to be changed. search in the forum how to work on it :)
PostPosted: Sat Sep 01, 2012 12:25 pm
To remove the starter you will have to take off the left side engine casing etc. To access the brushes only remove the oil cooler blank bolts and starter motor cap. I am fairly sure the 748 uses the same starter if it is really that bad, a common part.
PostPosted: Sat Sep 01, 2012 1:47 pm
All L twins in Ducati use the same starter :)
PostPosted: Mon Sep 03, 2012 11:16 am
Thanks to all. It was a short on the internal cable connection straight onto the casing after it slipped round whilst connecting cable.
It seems from comments that most parts are common with other models, does this include ignition items, ignition key etc, as my manual does not show grey cable on switch but there is one.
PostPosted: Mon Sep 03, 2012 12:45 pm
the wiring diagram shows a grey yellow (GRY) cable that runs to the left handle bar switch.
Numerous engine parts can be found on other Ducs. The Digiplex ignition is rather specific as is the ignition switch. The ignition switch from other Pasos will fit.
PostPosted: Mon Sep 03, 2012 6:56 pm
Similar digiplex ignitions were installed on Fiat and Lancia cars, but with a differend mapping. Ingition switch fron Cagiva Elefant can fit ;)
