ducatipaso.org • View topic - just an alternative to the old ciggy butt
It is currently Mon Sep 29, 2025 5:16 pm
 Post subject: just an alternative to the old ciggy butt
PostPosted: Sun Sep 16, 2012 1:00 pm
a couple of years ago i had this idea in my head after reading a few posts stating that the induction pressure fluctuation and or resonance in the air box caused some glitches at cartain revs by feeding too much info into the p7, and some bright spark came up with the cigarette butt idea to minimize this problem. :thumbup:
i just soldered some copper capillary tube to a small refrigerant strainer and connected two small 3/16 copper ends to the capillary which is the same size as the pressure sensor tube connectors and reconnected this gadget with the rubber tube and small cable ties, the top capillary tube is 1.2mm and the bottom 1mm in dia. see pic
this gadget acts as a muffler and should smoothen things out from any fluctuation, but still giving the correct absolute atmospheric air pressure from inside the air box...i didnt try it out as yet :dunno:
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
 Post subject: Re: just an alternative to the old ciggy butt
PostPosted: Mon Sep 17, 2012 3:07 am
Looks more complex....and expensive than a Ciggy Butt though.
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
PostPosted: Mon Sep 17, 2012 9:31 am
Cheers Claude.
PostPosted: Mon Sep 17, 2012 10:52 am
Hey Claude, was wondering where you where!!
crackin bit of work there.
I had Brad the Bike boy look at that FBF chip. He found it to be a lot richer and more advanced at lower evs and the same as the FIM in the higher rev range.
My bike runs even smoother now and was much improved at low revs with that chip, just better all round.
Just got mine back a while back after he fixed the barrel oil leaks, $$$$, but hardly done any riding.
ciao Nige
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
PostPosted: Mon Sep 17, 2012 12:32 pm
Cheers Claude.
PostPosted: Mon Sep 17, 2012 7:19 pm
Well, as you two are heading for spring and summer, it should be no problem. Here autumn and winter are approaching way too fast.
Temps in AUS are better any way . . . . so hit the tarmac both of you!
Proud owner of a;
- Ducati 907 ie 1992 in red
PostPosted: Tue Sep 18, 2012 12:33 pm
Cheers Claude.
PostPosted: Tue Sep 18, 2012 10:11 pm
What sort of stuff is inside the filter, I was just thinkin that being designed for refrigeration the filter medium wont be expected to cope with moisture and ... well that thing of yours may work better or worse depending on humidity ( or even worse and worser) Mmmmm Im also wondering about the length and diameter of those capillery coils and thier resonant frequency ... :D :D :D Ha ha , tell ya what tho , I had to see the irony tho ..... your pix of this invention ...... and your avitar
PostPosted: Wed Sep 19, 2012 2:14 pm
Cheers Claude.
Users browsing this forum: No registered users and 109 guests
