ducatipaso.org • View topic - What size Tyre can I run on the rear without Modifications?
It is currently Fri Oct 30, 2026 6:10 pm
 Post subject: What size Tyre can I run on the rear without Modifications?
PostPosted: Thu Aug 23, 2012 1:11 pm
I have recently Bought a 1989 906 Paso and can't find a rear tyre (160/60-16) anywhere. Can anyone suggest a tyre size to fit without any major modifications? Please Help
 Post subject: Re: What size Tyre can I run on the rear without Modificatio
PostPosted: Thu Aug 23, 2012 4:43 pm
My crystal ball says that you should contact Golden Tire in Italy for the answers to all your needs for round rubber bits, oh, and search all the posts for the past 10 years describing the difficulty in finding a tire size that went extinct as soon as it was on the market. Fashion is so fickle, and 16" tires were in fashion for about 6 months when the Paso was designed.
Good to have another member.
Cheers, phil
PostPosted: Thu Aug 23, 2012 10:27 pm
Metzeler me 880 goes straight on.No chicken strips left on mine,they hang on well! They last a while as well. J.
PostPosted: Sat Sep 22, 2012 2:59 pm
PostPosted: Sun Sep 23, 2012 11:12 am
PostPosted: Sun Sep 23, 2012 11:14 am
I have had the Metzeller 180/60-16 recently fitted to my 906. It fits fine and looks great also.
PostPosted: Sun Sep 23, 2012 6:11 pm
thanks for the info
you did not do any modifications regarding the chainline?
i did some measurements today - just for fun -. my 150 / 80 Avon Azaro is 165 mm (on the 5' rim of the Paso).
there is almost 10 mm left to chainline, hence, any tire that is below 180 mm (mounted on the 5' rim of the Paso) should have no serious connection to the chain.
given this table
viewtopic.php?f=1&t=3042&start=255
indeed the Metzler is the only 180 / 60 that should do it.
just as an info, i know there are more points to consider when trying to find a tire solution for the paso. still - beside the current goldentire option which the corret size - it is still nice to hear that there are at least some possibilities.
all the best, hardo
Users browsing this forum: No registered users and 22 guests
