ducatipaso.org • View topic - 907 parting out.
It is currently Wed Apr 22, 2026 11:44 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: 907 parting out.
PostPosted: Tue Jul 31, 2012 7:23 pm
I don't have a chip available but should have the mapping as a file. If you can find someone that can burn eproms, I can mail you the file so you have an eprom made.
A few years ago the eproms were still available from Ducati. Can't imagine it is a fast moving part, so perhaps your lucky there. Price was quite decent.
If you still have no ECU let me know, a friend of mine in the UK (from the Cagiva Elefant brotherhood) that fiddles a lot with these bikes might have 1 or 2 available.
Michiel
Michiel
http://www.endless-horizons.net
http://www.endless-horizons.net/efi/efi.htm
http://www.elefant.nl
PostPosted: Sat Aug 25, 2012 9:34 pm
well I got a computer and new coils but I still have no spark any ideas
PostPosted: Sun Aug 26, 2012 5:57 am
PostPosted: Sun Aug 26, 2012 12:40 pm
Nick beat me to it, I also think it's one of these sensors that is gone.
Datasheet can be found here:
http://endless-horizons.net/efi/rpm.htm
Michiel
PostPosted: Mon Aug 27, 2012 1:17 am
Recently saw some modified chips for a 907 with open mufflers on USA Ebay, for a too high prize for me. Perhaps you could find it there, were the last 10 or 12 pcs from that modification company. In house programmed. . . . . .
Proud owner of a;
- Ducati 907 ie 1992 in red
PostPosted: Mon Aug 27, 2012 5:37 pm
I pulled the connector from the coil and had good power through the initial turn on and when hitting the start button, So if power is there and the coils are new, you think it is another problem that would not allow spark to happen? I will check into this, but that is kind of odd. Thanks for the info I will look deeper.
PostPosted: Mon Aug 27, 2012 10:21 pm
Hi Duc24u,
actually when the 12V power to the coil is interupted by the ignition module you get a spark on your plug (break down of the magnetic field). you mentioned power on the plug, but when you turn the engine slowly by hand does the power drop off? with the engine running the power break down is only for a few milliseconds and hardly visible by the naked eye.
if the power does not drop of, the coils are not suspected, but the components "upstream" are.
Swapping parts with known functional ones is an option to isolate the defect.
you need a friendly donor, that's all.
Bertus
PostPosted: Tue Aug 28, 2012 6:30 am
PostPosted: Wed Aug 29, 2012 6:00 pm
You guy's are amazing that was it they were swapped, She fired up and I have never heard a sweeter sound...:O
PostPosted: Mon Sep 24, 2012 12:17 pm
There is a P8 computer being offered in the Netherlands, price 200 Euro. Sounds not too unacceptable.
I regularly visit this company for parts on older Ducati's. Also more Paso or 906 /907 parts available.
See the P8 here:
See the list of other items here:
Good luck!
Olaf
Proud owner of a;
PostPosted: Tue Apr 30, 2013 11:08 am
PostPosted: Tue Apr 30, 2013 7:42 pm
PostPosted: Tue Apr 30, 2013 11:26 pm
There are several owners here can set you up with all you need :beer:
