It is currently Wed Oct 01, 2025 4:01 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: '92 907ie cush drive
PostPosted: Mon Sep 24, 2012 3:59 pm
thanks Jaffa, G put me on to one on Ebay that I think will work . waiting for it's arrival. While I got her up might as well do that clutch .....
PostPosted: Wed Sep 26, 2012 7:45 pm
To summarize (late to the discussion) all of the sprocket carriers are the same starting from the 907 on up, except for:
- Bearing size (easy enough to change)
- New versus old pins (RH Vs, LH thread ) (although the pin into the wheel are the same size)
- Carriers for 4.5" wheels are machined a bit more on the sprocket side to bring the chainline inboard more than the 5.5" rims. (5 speed transmission compared the 6 speed transmission) But they started as the same casting as indicated by the numbers on them.
E-bay or used is your best deal as few people want them. If you run different gearing for trackdays or such, its a lot easier to have a spare sprocket carriers with different sprockets and just swap them out.
Get one from a 900 Monster or SS and you should be fine.
