It is currently Wed Mar 04, 2026 1:21 am
[ 6 posts ] |
| Author |
ahdoman
Post subject: Front Brake Light Switch Posted: Wed Sep 26, 2012 4:06 pm |
Joined: Sat Mar 19, 2005 12:00 am Posts: 107 Location: Santa Clarita, Ca.
I've been running down a few electrical gremlins on my bike and yesterday I realized that I don't have any brakelight when I use the front brake. Is the switch mounted at the hand lever? I've been through the manual and it's not clear. Could someone take a pic of how it's mounted? My perches look stock but I dont see how the switch would mount.
_________________ 1988 Red Ducati Paso 750 1999 BMW R1100S
| Top |
Post subject: Re: Front Brake Light Switch Posted: Wed Sep 26, 2012 5:31 pm |
| paso grand pooh-bah |
follow the brake line from the pump to the splitter at the lower triple clamp. There`s a pressure switch. Check TAV.18 of the parts caatlogue.
| Top |
Brutus
Post subject: Re: Front Brake Light Switch Posted: Wed Sep 26, 2012 8:47 pm |
Joined: Sun Jan 16, 2005 12:00 am Posts: 257 Location: The Netherlands
I've recently replaced the stock brakelines at the front with stainless steel lines. Just two lines from the pump to the calipers. Still have to add a micro switch on the ps13 pump lever instead of the pressure switch. Léon
_________________ _________________ Better too late than too ugly..
| Top |
Post subject: Re: Front Brake Light Switch Posted: Thu Sep 27, 2012 12:22 am |
Bevel Heaven has either of the lever mounted switch required when you loose the junction block and pressure switch with braided lines
| Top |
ahdoman
Post subject: Re: Front Brake Light Switch Posted: Fri Sep 28, 2012 6:17 am |
According to Ducati the stock switch has been discontinued. There's a local auto parts store in my area that caters to guys who do a lot with European imports. I took the old switch to them and he pulled a generic one from the shelf. The difference is it had the tapered pipe thread. He ran a 10mm x 1.0 die down the threads, cleaned it up and it works perfectly. Total cost; $22.50.
| Top |
whitepaso
Post subject: Re: Front Brake Light Switch Posted: Sun Sep 30, 2012 1:17 am |
Joined: Sun Feb 19, 2006 12:00 am Posts: 143 Location: Bolivar, Ohio USA
| Top |
[ 6 posts ] |
Users browsing this forum: No registered users and 10 guests |
