ducatipaso.org • View topic - Yet another new 907 ie owner. Maintenance questions.
It is currently Sat Apr 25, 2026 9:26 pm
 Post subject: Yet another new 907 ie owner. Maintenance questions.
PostPosted: Sun Oct 16, 2005 8:28 am
Hi all,
I have enjoyed my 15 year old italian, thus far. It's a far cry from my '81 Kawasaki kz550. Where can I get basic maintenace procedures? Like where is the air filter? And what do I have to do to inspect it? Do they make reusable air filters for this bike?
What tension do I tighten the chain to?
Any recommendations on engine oils? I know that question always starts an interesting thread.
Should I be worried that the motor shakes signifigantly below 3k RPM?
PostPosted: Sun Oct 16, 2005 10:47 am
Hi newbie!
You can find maintain table from Owner manual, what can downloaded (I think..) from Download section in this Ducatipaso.org site.
If need to change air filter, U have to take fueltank away and U see then hole air intake system. If You want GOOD air filter to Your hole life, buy K&N. They have one for 907 and surely same element fit to all Pasos... Also chain tighten U can find from owners manual!
Near everybody uses different oils, but i have read lot about this and i recomend Fully synthetic Shell Advance Ultra 20W-50, what is good for "lower" transmission connection noises, and ITS VERY GOOD quality oil. Change oil filter every time, U change oils to engine and surely check also that "hard filter" in right side of engine,,, remembering 24mm wrench.... surely have to take one small part of frame away, but only 4 bolts....
I think, never use engine lower rpms, than 4000(when driving)U can feel too low rpm in Your ass very easily,, if too low rpm, surely better put smaller gear, than destroy some bearings from engine :evil:
Antti
PostPosted: Mon Oct 17, 2005 1:56 am
Does the engine shake alot while at idle?
If you're in gear at under 3,000, finnpaso is right, you are damaging the motor. These bikes don't like to be lugged at low speed like you could with a kz 550 four cylinder bike.
PostPosted: Mon Oct 17, 2005 3:39 am
No at idle engine does not shake hardly, just when opening throttle too much at 3500 RPM or below when in gear on the highway. Also startted having odd issue with finniky engine kill switch. For no apparent reason engine would not start Moved engine kill switch around and engine starts normal. Can these be opened and cleaned at all, it looks to me like it is sealed. Thanks all for replies.
PostPosted: Mon Oct 17, 2005 1:13 pm
When I am in gear on my 907 at that rpm, it kind of bucks and shakes too. Hard to get used to at first, and makes the bike less of an "around towner"...so just something to learn not to do. As for the kill switch, it could be corroded, dirty or the metal tabs are broken from years of use. You have 3 choices, take it off and carefully try to open it--clean or fix yourself, disable it and just use your key as kill switch or try to order a new one from:
http://www.powersportspro.com/partsfish/
PostPosted: Mon Oct 17, 2005 3:00 pm
As others have said, avoid low rpm/heavy load situations. If you're at 3000rpm and you want to accelerate, downshift first. Lugging a Ducati engine is cruel and unusual punishment...
Regarding the K&N air filter - I put one on my 907 and kept it installed a grand total of one day. I hated it. At 80mph I could hear intake noise over the wind noise. The day I tried it out it was very hot. Bike ran horribly at lower speeds, to the point I had to stop and let it cool off a few times when I got stuck in traffic on my way home. No, I hadn't done anything to adjust the injection and it obviously needed it. Went back to the stock filter, and no more problems. I later installed the K&N on a 900ss and it worked much better - but the bike was jetted for it. Still loud though. At a certain rpm, tucked in with your head down by the tank, it felt like your helmet was about to explode. I'm not kidding... painfully loud. One more reason to wear earplugs.
I seem to remember the 907 airbox lid needs to be modified to run a K&N, but that was many years ago, they may have one now with a lower profile that will fit under a stock lid? Moot point for me anyway as I'm happy running the stock filter on that bike.
-Craig
PostPosted: Mon Oct 17, 2005 6:17 pm
I have "lower" and "higher" profile K&Ns and both fit perfectly without any modifications to airbox :thumbup:
About noise: I use allways earplugs when driving my Ducatis and such sounds belong to "Ducatiworld" :cool: All mecanical noises belong to Ducatis! If want silent bike, better choose singer then.
Btw, i need ALSO free flow air filter, cause my 907 engine have open exhaust, ported heads, ST2 cams and surelu more fuel to make more hps, so also remapped FIM chip.... and best to take only snorkels away, not "all airbox cover open"...
Antti
PostPosted: Mon Oct 17, 2005 9:54 pm
My local bike shop says K&N doesn't make a filter for my 907ie. Does anybody have a part number or know another bike that the filter will work from?
PostPosted: Mon Oct 17, 2005 11:08 pm
Do you have a Ducati dealer nearby? I have a K&N in mine and it works and fits just great. Not too loud either. (I don't wear earplugs) Find a dealer and have them order one. Alot of bike shops don't spend the extra time to look very hard. You will learn that with this bike.
PostPosted: Tue Oct 18, 2005 12:20 pm
propably same ordering number, as to 750.... I cant remeber, where i get those..... Anyway K&N have filter to 907, I am 100% sure of that :thumbup:
Antti
PostPosted: Wed Oct 19, 2005 4:36 am
PostPosted: Wed Oct 19, 2005 4:09 pm
PostPosted: Fri Oct 21, 2005 8:27 pm
Thanks all for the replies, I did find that the local place can get a UNI foam filter for my 907ie, does anyone have an opinion on UNI Filters?
PostPosted: Mon Oct 24, 2005 11:17 am
90_907ie,
The kill switch problem has been covered in the past. It is caused by badly designed electrics on the Ducati. Search for a posting by JSclocum to explain why. He also provides a suggested wiring modification to increase the voltage at the colis which will help prevent it happening again (it doesn't fix the problem if the switch is already damaged).
Paul
