ducatipaso.org • View topic - Lift/jack
It is currently Wed Jun 17, 2026 2:20 pm
 Post subject: Lift/jack
PostPosted: Thu Oct 18, 2012 7:30 am
Hello,
I need to do some work and be able to take both wheels off my Sport at the same time.... Can anyone recommend a good and rather inexpensive idea for a lift/jack?
Thanks!
Prince Fritz First
 Post subject: Re: Lift/jack
PostPosted: Thu Oct 18, 2012 3:40 pm
I use two jack stands under the foot peg brackets and scissor jack and block of wood under the base of the front cylinder. Or you could support it with a rod through the swing arm pivot, and jack stands.
If you have sturdy rafters, a hoist works great.
Or you can build a simple stand from lumber.
Yes, you have to remove the fairing.
PostPosted: Mon Oct 22, 2012 5:27 pm
Could you not just use paddock stands on blocks of wood or something?
PostPosted: Mon Oct 22, 2012 8:27 pm
PostPosted: Mon Oct 22, 2012 9:12 pm
Most certainly the best way is a pair of paddock stands. For the rear, the common one that lifts on the swing arm. For the front a stand that fits under the fork legs, or one that fits under the lower triple clamp. (I have acquired both) . I bought all of these after precariously hoisting my bike on the jackstands, which indeed were cheap, because I had them already.
There is also a very cool work stand that has a large hoop over the bike and a ratchet strap to lift the bike up. Takes up a lot of space in the shop, but the fastest way to lift a bike safely.
Search your local want ads to find someone selling paddock stands for cheap. They always come up from time to time, you just need to be patient. New they can be $200 each, but used you can find them for $50.
PostPosted: Thu Oct 25, 2012 7:17 am
Abba Stands from UK are good, I plan on getting one myself. They are about £100. They do fitting kits for most bikes.
http://www.abbastands.co.uk/
PostPosted: Thu Oct 25, 2012 8:57 am
I've been using an Abbastand since I bought my previous 900SS back in 2000. I've been using it ever since for various bikes. They are a tremendous piece of kit, well worth the initial outlay.
PostPosted: Thu Oct 25, 2012 4:15 pm
Indeed, a nice bit of kit. I hadn't seen that one before. Makes a lot of sense.
Thanks for showing us that.
PostPosted: Sat Oct 27, 2012 10:09 am
