ducatipaso.org • View topic - Paso 750 & 906 Transmission Components
It is currently Tue Oct 27, 2026 1:29 am
 Post subject: Paso 750 & 906 Transmission Components
PostPosted: Thu Nov 01, 2012 5:12 am
Hi All,
Can anyone confirm that the transmission components of the Paso 750 & Paso 906 are identical / interchangeable?
Looks like I may need to rebuild my Paso 750 transmission and have found one from a 906.
Thanks,
Gman
 Post subject: Re: Paso 750 & 906 Transmission Components
PostPosted: Thu Nov 01, 2012 7:14 am
It would be the same as a 750 sport , but not a 906. The 906 bottom end is basically from a 851 916 set up where as the paso750/ 750 sport is pantah based
PostPosted: Thu Nov 01, 2012 8:23 am
Aussie prices are a joke,try Ed Milich , Ducpower in the states.I have purchased several items from him including a paso transmission,no problems,just the normal two week shipping delay. J.
PostPosted: Thu Nov 01, 2012 9:47 am
P750 5 gears - 906 6 gears.
The easiest will be you look for a gearbox from a 750SS (carbed, -96). Get the part catalogues and compare part numbers.
PostPosted: Thu Nov 01, 2012 9:57 am
The 600SS/Monster will be the same.
PostPosted: Thu Nov 01, 2012 1:16 pm
PostPosted: Fri Nov 02, 2012 10:08 am
Thanks Angelix, that's useful info to know about.
PostPosted: Sat Nov 24, 2012 11:56 pm
I have found some transmission components on eBay.com
Can someone please confirm that these will suit a 1988 Paso 750?
"Ducati F1 Paso Late Fine Spline Transmission Cagiva TT2
good late, fine spline output shaft 5 speed tranny - for late Paso, F1B, adn other pantahs. Worked fine when removed. These are a great upgrade for earlier trannys."
Thanks in advance!
Gman
PostPosted: Sun Nov 25, 2012 4:34 am
That transmission will fit directly to your motor. This is a much better trans than your original.
You will also need the clutch hub from the Sport, as the spline count is different.
