ducatipaso.org • View topic - New Project 907 evo
It is currently Thu Oct 29, 2026 9:26 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: New Project 907 evo
PostPosted: Sun Nov 04, 2012 10:02 am
After several weeks away from home I picked up a 906 with a bad Motor (Crank shaft broken).
I stripped the Bike
And here is the new engine and Swingarm
In concept, it will be a 906 frame with 907 plastics and Monster technic (S4R Fork, Swingarm, Engine, Wheels, brakes....)
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
 Post subject: Re: New Project 907 evo
PostPosted: Sun Nov 04, 2012 4:29 pm
Great project, hope you got room for that motor. Plenty of pics as it progresses please.
PostPosted: Sun Nov 04, 2012 8:31 pm
:shock: :thumbup:
PostPosted: Mon Nov 05, 2012 10:40 am
even though I like projects I think it`s a pitty to see another good looking Paso go.
I have doubts you`ll get that engine and swingarm in as on newer Ducs the engine is hanging in the frame while on the Paso it`s "in" the frame with the swingarm connected to both. The shock will probably be too short and the large fork tubes may hit the tank.
Will you keep the injection system or convert to carbs ?
PostPosted: Mon Nov 05, 2012 11:35 am
I will be not an easy project
The 906 looks good on the picture but all plastic parts has cracks, dents in the Tank, the motor was in peaces, crankshaft is broken. Electric, let say modified....
It will be a 906 frame + 907 plastic + all Technik from a Monster S4R - no carbs.
Does someone needs 906 technic parts, Tank, wheels, brakes?
No water cooler, I place him in my black 907.
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Mon Nov 05, 2012 9:10 pm
Hi Bock900R,
I must say you found your self a nice challenging project.
But from what I saw, you can bring this to a happy end.
just curious about your about next project? maybe a 750 Paso Panigale?
well, would love to see your progress in pictures.
Bertus
PostPosted: Mon Nov 05, 2012 10:21 pm
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Mon Nov 05, 2012 10:29 pm
Hello Bock,
I planned to stay home and take a few weeks off to finish my lathe. that gives me the possibility to start produce Paso parts. I'm busy with that lathe for 3 years and want it in operation. then I start to work on one of the milling machines. the other machines as a tool grinder and shaper don't require much work. once the shop in operation I can do most of the jobs by myself.
Bertus
PostPosted: Tue Nov 06, 2012 6:44 am
Good luck!
A real challenging project.
As Mr. G. said, you will have to do many, many modifications to fit the ST4 engine (and the rest, of course) into the Paso frame.
If you'd have got a 851/888 engine it would be easier.
And, like Gerhard, I also would be more conservative restoring the bike.
However, let us see how the work goes on.
Ciao :beer: :beer: :beer:
PostPosted: Tue Nov 06, 2012 7:59 am
Great project start. All the parts in hand and ready to play. I foresee many hours in the garage fitting parts and fiddling. Should be one of kind in the end. Kind of just blowing right past the idea of restoration and landing squarely in the neighborhood of Hot Rod / Custom. I see an entry to Bike Exif, or Pipeburn.
Hope your project goes faster than my stalled 750 Sport project.
PostPosted: Tue Nov 06, 2012 2:10 pm
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Thu Nov 08, 2012 12:06 pm
:beer: :thumbup:
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
PostPosted: Thu Nov 08, 2012 6:14 pm
I have a 907 that I started to put 916 power into it. It became aparent that the tall 916 heads would hit the front wheel. I don't know much about the 851 or 888, but if they are the same as a 916 then the monster S4R with short heads should IMO be much better. On my project, I got a crashed ST4(engine) with short heads to shorten the 916 engine. All the electrics and guages are from a 916 so the mechanical tach is not required in my case.
good luck with your project.
92 907 bought new
92 907/916 project
02 MS4
:thumbup:
PostPosted: Thu Nov 08, 2012 6:46 pm
It is a S4R Engine with the shorter Head in my garage
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Thu Nov 08, 2012 8:07 pm
I put showas on my 907 using SS yokes, they have 4mm longer offset moving wheel forward a few mm. Although the wheelbase is legthened slightly the trail is reduced so steering agility is not affected. I would guess the wheel is moved forward by about 2.5mm. You could also fit a lower profile tyre (120/60). I used one for a while it was ok. 10mm smaller diameter.
