ducatipaso.org • View topic - part swapping ?
It is currently Mon Sep 29, 2025 1:24 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: part swapping ?
PostPosted: Mon Nov 05, 2012 5:53 pm
Hi Derek,
just a dumb question. :) can't you make a M12 hole out of the M6? I guess there is still enough material to do so. because it takes more to change patterns than to change machining programs.
Bertus
PostPosted: Mon Nov 05, 2012 7:03 pm
PostPosted: Mon Nov 05, 2012 9:06 pm
Hi Derek,
I check out on my ST2. as you said, metal enough.
when you bolt the left lower part of the frame, you can use that as a jig.
I've added some pics of the cylinder and engine
Bertus
PostPosted: Tue Nov 06, 2012 9:39 am
Thanks Bertus, that's what I intend to do.
