ducatipaso.org • View topic - new member with questions
It is currently Wed Oct 28, 2026 12:34 pm
 Post subject: new member with questions
PostPosted: Fri Nov 23, 2012 7:26 pm
Are they still available? Hi, I'm new on these forums and have a few questions about Pasos. The firs one being the tires. I have 120/80-16 M/C 60T front in excellent shape and 159/80-16 71H rear, to be replaced.
1. Are the sizes right?
2. If not, what should I fit?
3. I've got issues with the Weber carb diaphragm
4. I need new clutch discs, any recommendation? Are Khamma (Germany) ok?
If you are not the expert on these general topics, please refer me in the right direction.
Thanx
 Post subject: Re: new member with questions
PostPosted: Sat Nov 24, 2012 10:07 am
as you`re new just some general (unwritten) forum rules. Do check the manuals first and use the forum`s search function. Then please open your own thread unless your questions fit to an existing one.
1. no
2. see user manual or FAQs
3. what`s the question ?
4. Kämna doesn`t make clutch discs. The most common are ADIGE or SURFLEX.
PS: adding your location to your profile would help
PostPosted: Sun Nov 25, 2012 10:52 pm
I think these tire sizes are wrong. I use in my Paso 130-70-16 and 180-60-16. I used 150-80-16 and this size is very high tire and the 5th gear is very, very long, and it is very thin and lose grip suddenly when you are inclined.
70 hp. can change the world
