It is currently Sat Feb 28, 2026 5:08 am
 Post subject: Red Paint spec for 750 Paso
PostPosted: Sat Dec 01, 2012 8:32 pm
I need to paint a couple of parts on my red '88 Paso and wonder if anyone knows the paint number, name, or has come up with a matching substitute. Could you email me at docbob1@msn.com.
thanks,
Bob Unger
 Post subject: Re: Red Paint spec for 750 Paso
PostPosted: Tue Dec 11, 2012 9:27 pm
You could try this:
I had the paint mixed to match my Paso.
Take a part of your bike that has good color.
Go to your local auto paint supply shop most shops have an optic scan device that reads the color spec combinations between white at the high end and black at the low end with everything between.
The paint shop will make you a custom can (it could be expensive maybe $50 to $100 US) based on size or volume of paint you need.
You will also need a can of clear coat to give the finished look, this is a stock standard item.
Good Luck.
Users browsing this forum: No registered users and 32 guests
