It is currently Sun Apr 26, 2026 3:41 pm
| Author |
nickta
Post subject: Re: A tailight mystery Posted: Fri Dec 21, 2012 9:00 am |
Joined: Tue Jul 24, 2012 8:54 am Posts: 287 Location: Cairns, Queensland, Australia
Get the colour version of the Wiring Diagram off the 907 documents link, from memory, in the "manuals" sub directory. Print it in colour and on A3 and its like looking at the bike!
Out of curiosity, does the tailight come on when the ignition switch is in the "Park" position? The Tailight is fed from 2 different fuses, depending on what position the switch is in. If it works in one and not the other, it might be a dodgy contact in the switch.
Cheers.
Nick.
| Top |
2vtwin
Post subject: Re: A tailight mystery Posted: Wed Dec 26, 2012 3:09 am |
Joined: Mon Jun 22, 2009 9:40 am Posts: 45 Location: USA
_________________ "It's about the Journey, Not the destination" AMA Charter Life Member, Victory Motorcycle Club, Charter Member, Patriot Guard Rider 02' M900 01' Victory SC 04' Victory KP 09' HD XR1200 14' Ducati Diavel 16' Victory Cross Country Tour
| Top |
2vtwin
Post subject: Re: A tailight mystery Posted: Wed Dec 26, 2012 3:11 am |
| Top |
2vtwin
Post subject: Re: A tailight mystery Posted: Wed Dec 26, 2012 3:13 am |
| Top |
2vtwin
Post subject: Re: A tailight mystery Posted: Mon Jan 14, 2013 12:28 pm |
The parking light is not working either. I have checked all the fuses including the 2 15A fuses in the left front behind the fairing. The ehadlight works on both high and low beam. Does the prking light control the tailight somehow? - Gene
| Top |
Derek
Post subject: Re: A tailight mystery Posted: Mon Jan 14, 2013 8:29 pm |
| paso grand pooh-bah |
The tail light and parking light are on the same circuit. The circuit is grey/yellow from the fusebox to the lighting switch which switches it through to a grey/black when the lights are on. This takes it to the ignition switch where it is routed to a Yellow/red to both the tail and parking lights. The ignition switch also connects the yellow/red to the blue from the fuse box when it is switched to the 'park' position. First check the 15A fuse although that's unlikely to be at fault as you wouldn't have a headlight ether nor would the starter solenoid operate. If the park/tail lights operate with the ignition switch in the 'park' position the fault is with the lighting switch or the wires to it. If not then it can only be the yellow/red wire form the ignition switch to the parking light, possibly a break or poor connection. The diagram shows the wire then continuing from the parking light to the tail light where it becomes a yellow wire at the tail light connector.
| Top |
Users browsing this forum: No registered users and 17 guests |
