ducatipaso.org • View topic - poor running
It is currently Sun Sep 28, 2025 10:52 pm
 Post subject: poor running
PostPosted: Tue Jan 01, 2013 12:40 am
hello everyone, i am having a running problem with my 907. its running too lean(at about 2% co) and it will not adjust. i checked the voltage on the 2 wires that come from ECU and there is 12.3v all the time and i dont think it should be that high. i also checked the voltage at the adjuster and it goes from 0 to 5 volts so its ok, if anyone knows what the voltage should be to the injectors that would be great.
thanks and happy new years
 Post subject: Re: poor running
PostPosted: Tue Jan 01, 2013 1:57 am
Is the TPS set correctly?
The CO adjuster on the ECU don't make any difference?
Are the idle balance screws fully turned in? Fully in gives less air
& richer at idle.
PostPosted: Tue Jan 01, 2013 12:37 pm
Info on proper tuning
