It is currently Fri Oct 30, 2026 6:55 am
 Post subject: unhappy Paso :(
PostPosted: Sat Dec 29, 2012 4:32 pm
HI everyone,
I hope you had a great holiday season. Sadly, my 90 906 didn't. At the end of the season last year, the bike started back-firing through the carb and right exhaust. After some back yard diagnostics, I found I had intermittent spark at the one coil. I replaced it,fired it up and all was good.......then the bike shut off and hasn't re-started. I have no spark at either coil. NOT COOL. Any ideas of the culprit and an ignition system upgrade? Thanks for any input :thumbup:
 Post subject: Re: unhappy Paso :(
PostPosted: Sun Dec 30, 2012 12:10 am
I had an issue recently where I had no spark at either coil but when I tested them with a volt meter there was power to both terminals. I finally found that there wasn't a proper connection between the coil and the frame.
PostPosted: Sun Dec 30, 2012 9:13 am
Check also the pick up.
PostPosted: Sat Jan 05, 2013 3:49 pm
i would take a look at the pick up also (same as fiat uno car )sounds like it failed
PostPosted: Mon Feb 25, 2013 11:03 pm
Hi everyone,
Thanks for the tips concerning my sickly 906. I tool out the pick-up sensor & discovered the previous owner had spliced it. (it must have burned at some point) Now, I can't seem to find instructions to test it. I checked the service manual and internet,no luck. I was going to just replace it,but haven't found any in the USA. Any suggestions? THANKS! :thumbup:
PostPosted: Tue Feb 26, 2013 9:10 am
viewtopic.php?f=2&t=5843
