ducatipaso.org • View topic - Fairing bolts on eBay, any good?
It is currently Wed Oct 28, 2026 6:49 pm
 Post subject: Fairing bolts on eBay, any good?
PostPosted: Sat Aug 25, 2012 1:52 pm
Finally getting some time to put this bike on the road (sitting in the garage since I found it this past spring). PO took the fairing apart years ago and lost some of the bolts and many of the rubber bushings are in crap condition. These bolt kits aren't cheap but I'm willing if they're quality. If anyone has experience with these kits please let me know.
http://www.ebay.com/itm/NEW-88-89-90-91 ... 3a6e42085e
I know I'll have other questions but I've already found good info in previous threads. Can't wait to ride.
 Post subject: Re: Fairing bolts on eBay, any good?
PostPosted: Sat Aug 25, 2012 3:45 pm
I've been wondering the same thing since a couple of my rubber inserts are rotten. The Paso 750 has a total of 24 of those rubber grommets if you include the oil coller covers, 14 if you don't. In the picture they show 18 of the grommets.
1988 Red Ducati Paso 750
1999 BMW R1100S
PostPosted: Sat Aug 25, 2012 6:01 pm
I believe this ad is just for bolts, nothing else, and they are incorrect in terms of head and construction. Original fairing bots are not button heads, and are hollow, not solid. Those bolts are heavy and high profile and if you want them, they are available from McMaster-Carr catalog for about $1US each plus shipping. ;)
PostPosted: Sun Aug 26, 2012 12:34 am
The bolts on ebay dont fit any Paso forget them.....
Get them cheap as stated at McMaster Carr
PostPosted: Sun Aug 26, 2012 5:27 am
Got a similar set of these on my Paso for the couple of years now ..no problems, still look good as new
1990 750 Paso
2011 Suzuki Bandit 1250 S
PostPosted: Tue Jan 29, 2013 7:21 am
nice posts and forum.thanks for sharing...
PostPosted: Tue Jan 29, 2013 12:53 pm
If you need rubber bolts, I use these:
http://www.rawlplug.co.uk/index.php?opt ... &Itemid=34
RNT-M6/16
I bought them at a Fabory shop.
Kawasaki Z700 1987, Kawasaki ZL1000 1990, Ducati PASO 750 1990,
Ducati 900ss 1993, Ducati Paso 906 1990
PostPosted: Tue Jan 29, 2013 6:31 pm
PostPosted: Wed Jan 30, 2013 1:48 am
fuck the ebay kit it don't fit You will have to close up all you mounting holes and redo them. It is a nice kit it just don't work move along nothing to see with the ebay kit :banghead:
PostPosted: Wed Jan 30, 2013 6:01 pm
Phil:
This is as close as McMaster Carr gets to our fairing bolts. They are the wrong head, and are solid steel, but they are closer matches than any thing else I've found, and they do work.
1: 92137A535Metric Flange Button Head Cap Screw Alloy
Steel, M6 Size, 20 Mm Length, 1.00 Mm Pitch
2: 92137A644Metric Flange Button Head Cap Screw Alloy
Steel, M8 Size, 20 Mm Length, 1.25 Mm Pitch
:beer:
PostPosted: Thu Jan 31, 2013 2:52 am
++ :beer: :beer: McMaster Carr
Users browsing this forum: No registered users and 30 guests
