ducatipaso.org • View topic - Clutch pump 999
It is currently Tue Apr 28, 2026 3:18 pm
 Post subject: Clutch pump 999
PostPosted: Thu Feb 14, 2013 6:29 pm
Hi!
Who has made something like that already?
I'm on the way to change the pump of the braking and the clutch of my 907.
How did you manage, that the starter level (Choke / Levetta per starter?) on the left hand is working?
Is it possible to lay the cable to the underside?
Would someone be so kind to make a photo from underneath?
Thank you.
Ahab
 Post subject: Re: Clutch pump 999
PostPosted: Thu Feb 14, 2013 6:42 pm
that starter assy is mounted upside down.
(do you have an Alfa ? That tool on the wall looks somehow familiar)
PostPosted: Sat Feb 16, 2013 6:59 am
Io ho la stessa pompa sui freni anteriori e mi ha cambiato la vita.
E' veramente tutta un'altra cosa.
Avevo comprato anche la pompa frizione su ebay (entrambe provenienti da un 999) ma il meccanico mi disse che non poteva andarci sul Paso.
Comunque ha ragione G.: devi ruotare lo starter in avanti. Adesso รจ in posizione sbagliata.
Buon lavoro :thumbup: :thumbup: :thumbup:
I've got the same brakes' master cylinder on my red 907 and it has really changed my life.
It grants a very stronger braking.
I bought the couple of master cylinder from a 999, but the mechanic told me the clutch master cylinder did not fit on the Paso.
Really, I don't know why.
However, G. is right, you have to rotate the choke assy which now is wrong.
PostPosted: Sun Feb 17, 2013 4:20 pm
Hi guys,
of course i know that it's upside down, because it didn't fit. I rasped down one of the black pins, and now it works. The starter wire is very close to the clutch line.
The tools are for bevel Ducatis.
PostPosted: Sun Feb 17, 2013 5:13 pm
What about those 2 switches on the left?
Che sono quei due pulsanti a sinistra?
Curioso come una scimmia :lol: !!
PostPosted: Sun Feb 17, 2013 6:53 pm
PostPosted: Sun Feb 17, 2013 8:39 pm
It's a
http://www.translogicuk.com/powershifters.php
I lost parts of my left leg, so I have to shift this way.
PostPosted: Sun Feb 17, 2013 11:13 pm
I'm really sorry.
I could not imagine such thing.
Sorry again.
