ducatipaso.org • View topic - front end? steering? Weird
It is currently Tue Sep 30, 2025 2:27 am
 Post subject: front end? steering? Weird
PostPosted: Fri Mar 15, 2013 9:28 pm
Took the 907 out for the first time this year with proper air pressure and a bolt tightness check, oil, chain tension and lube and a quick polish. It seems to tip in early and hard and is quite sensitive to steering inputs. Not the rock solid stable long curve tourer that I remember! Could it be that I'm totally out of sync with the bike since my off-season Bevel Scrambler riding? Or is there something amiss in the front end that I need to check?
Sheldon
 Post subject: Re: front end? steering? Weird
PostPosted: Sat Mar 16, 2013 4:53 am
Hmmm. Maybe you are just riding slower than you used to. Try going 20-30 mph faster.
:cool:
Phil
PostPosted: Sat Mar 16, 2013 7:51 am
PostPosted: Sat Mar 16, 2013 10:07 am
you did say with proper air pressure...this is typical of under inflated front tyre pressure, check your air pressure gauge...going by memory 34psi front 36psi rear?
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Sat Mar 16, 2013 5:44 pm
Yep, Claude. Those are the numbers I put in. But I'll check the gauge and the pressure again!
Thx.
PostPosted: Sat Mar 16, 2013 6:35 pm
Hi Sheldon,
how about your steering head bearings. when they are gone, you'll face funny steering also.
put the bike on the centre stand and place someone or something on the rear of the saddle so the front wheel comes of the ground. now you should be able to turn the steer from side to side without strange behavior during the turning.
Bertus
PostPosted: Sat Mar 16, 2013 8:19 pm
Good idea Bertus. Will try and report.
Sheldon
PostPosted: Sat Mar 16, 2013 10:03 pm
Next check wheel bearings, then swingarm pivot.
PostPosted: Sat Mar 16, 2013 11:27 pm
also good ideas. Wheel bearings are good. Swing arm pivot will check. Starting to look like it's a rider issue. I guess I have to go faster!
PostPosted: Sun Mar 17, 2013 8:45 am
and , seeing as christmas dinner has been and gone sinse your last ride are you sure there isn't a bit more WEIGHT over the front wheel than before :lol: :lol: ( does the tank appear to be bigger ? :lol: :lol: )
PostPosted: Mon Mar 18, 2013 10:02 pm
how are your fork seals? Just wondering if the oil level is ok or if the forks may have leaked oil which could become noticable.
On the other side I rode my 600 Gilera a couple of years ago, came home and got on the Paso instantly. Now a P750 handles a bit different than a 907ie and for a while it felt like driving a tank. :truck:
PostPosted: Wed Mar 20, 2013 11:20 am
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
PostPosted: Wed Mar 20, 2013 12:15 pm
Cheers Claude.
Users browsing this forum: No registered users and 55 guests
