ducatipaso.org • View topic - Dellorto blowback
It is currently Sat Mar 07, 2026 8:21 am
 Post subject: Dellorto blowback
PostPosted: Fri Nov 26, 2004 11:07 pm
Try this on for size. i get blowback through the horizontall cylinder carburettor, when bike has warmed up. changed the coils, reguiator,battery and spark plugs.
PostPosted: Sat Nov 27, 2004 9:10 am
:confused:
This sounds a bit strange, minimad. If you're having trouble on just one cylinder, why change the regulator and battery? If the trouble is spark, how come it only happens when the motor's warm? How about checking out the front carburetor? Does it blow back under acceleration, or at idle? Maybe the front carb is rich, so it runs OK only when cold.
PostPosted: Sat Nov 27, 2004 10:15 pm
Idie or acceleration it dos't change,and ouly when warmed (about 20mins after startup). changed jet size to bigger one, still didn't change.
PostPosted: Sun Nov 28, 2004 2:22 am
How well are your carbs synchronized, are you using reccomended plugs, and does the front plug look rich or lean?
PostPosted: Sun Nov 28, 2004 3:06 am
yes and yes. it's carbon fouling both spark plugs, with both bigger jets and small jets. it's like the motor start to run on one cylinder, and starts to fire at uneven times. can't reuse spark plugs again, even after cleanup. (motor won't start)
PostPosted: Sun Nov 28, 2004 3:50 am
So you're having trouble with both cylinders?
 Post subject: Re: Dellorto blowback
PostPosted: Sun Nov 28, 2004 1:45 pm
PostPosted: Tue Nov 30, 2004 4:59 am
PostPosted: Tue Nov 30, 2004 6:31 am
PostPosted: Tue Dec 21, 2004 10:49 am
PostPosted: Mon Dec 27, 2004 1:29 am
:cool: Thanks to all your help. happy riding
PostPosted: Mon Dec 27, 2004 9:31 am
I would agree with jomo on this one look for airleaks
