ducatipaso.org • View topic - New Owner, just put on new clutch pack and still slipping
It is currently Wed Oct 28, 2026 4:08 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
 Post subject: Re: New Owner, just put on new clutch pack and still slippin
PostPosted: Sat Mar 23, 2013 11:37 am
I've done the quiet clutch mod to three bikes now and didn't to any bending the extra friction plate. In each case I installed a old steel friction plate first before the rest of the pack. To get the stack height right I had to miss out one of the 2 plain steel plates that normally go in first and on one of the bikes I had to swap one of the other 2mm plain plates for a 1.5mm plate. That was it. No problems since in many thousands of miles.
PostPosted: Sat Mar 23, 2013 12:00 pm
hi Derek, I never had my clutch apart, I will get couple of old friction plates, is the friction plate the inner shaft plate or the outer basket plate (I immagine the inner) then the rest sounds like bit of trial and error...
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Sat Mar 23, 2013 12:23 pm
PostPosted: Sat Mar 23, 2013 1:14 pm
thanks Derek :thumbup: :thumbup: :thumbup:
Cheers Claude.
