It is currently Thu Oct 29, 2026 3:12 pm
 Post subject: Ignitech for 906?
PostPosted: Fri Mar 29, 2013 9:54 am
model: other
year: 1999
Is there an Ignitech available to replace the Digiplex in case of unrepairable failure? Would one have to fit Kokusan type ignition pick ups and flywheel, or would it be plug and play?
2013 M1100Evo Street
1999 M750 "Scrambler"
2004 GSXR750 Track
 Post subject: Re: Ignitech for 906?
PostPosted: Fri Mar 29, 2013 6:21 pm
Hi Koke,
maybe not ignitech, but maybe these guys: http://www.carmoelectronics.com.au/inde ... grnvhlpdl2
Bertus
PostPosted: Fri Mar 29, 2013 10:31 pm
model: other
year: 1999
Cool. Thanks :thumbup:
2004 GSXR750 Track
PostPosted: Thu Apr 18, 2013 8:28 am
I emailed Ignitch asking that very question and this was their reply:
Hello
There are two possibilities :
1) unit TCI (unprogrammable).
2) unit TCIP4 standard (programmable).
Both our unit do not contains sensor of inlet pressure (original unit it contains inside). But we think that this is possible run our unit on this bike without this sensor. We made this many times.
Unfortunately we have not original connector. You have cut original connector and to use another connector delivered with our unit.
What is your country ?
Regards.
IGNITECH
PostPosted: Mon Apr 29, 2013 11:21 am
Another one to try is Silent-Hektik in Germany. Haven't used the product myself but it seems to be a plug in replacement and they also offer coils and leads claiming improved performance over the standard items. You can use google translate to get more info from their mainly German web site.
They were quite responsive when I enquired in more detail some years ago.
http://www.silent-hektik.com/Duc_Digi.htm
http://www.silent-hektik.com/PB_DP_08.pdf
PostPosted: Thu May 02, 2013 7:22 am
model: other
year: 1999
Thanks.
I like the Ignitech. Set your own map for high compression pistons and fuel availability. Cool.
The water cooled 906 seems a good candidate for a high comp/big bore kit.
:thumbup:
2004 GSXR750 Track
