ducatipaso.org • View topic - Axle clamps?
It is currently Sat Feb 28, 2026 11:21 am
 Post subject: Axle clamps?
PostPosted: Wed Mar 27, 2013 7:40 pm
Anyone have one they'd like to sell? Found a crack on the left side one on our Paso. (called "U Bolt" on the microfiche).
Here is the strange part. Microfiche shows both sides having the same part number. But they are clearly different. A minor difference, you can see how one side has a machined groove, that is in mirror opposite on the other clamp.
Anyone think the machined groove matters?
 Post subject: Re: Axle clamps?
PostPosted: Thu Mar 28, 2013 3:41 am
PM sent
PostPosted: Thu Mar 28, 2013 9:31 am
yes, the groove matters. The swingarm has the same and the excenter sits in it.
PostPosted: Thu Mar 28, 2013 1:18 pm
PostPosted: Sat Mar 30, 2013 6:12 pm
If ducati spare parts microfiche shows the same # there must be some mistake. I think you can only look at advices for scraped and dismantled pasos and send a PM to ask fot what you need. Anyhow you can make it machined in Avional or similar alu materials even fi it will not look like the OEM one
PostPosted: Sun Mar 31, 2013 12:15 am
Either there is a mistake in the parts numbering OR the parts are only available as a pair ???? :D
PostPosted: Sun Mar 31, 2013 1:54 am
