ducatipaso.org • View topic - 3d chain slider
It is currently Wed Oct 28, 2026 5:28 am
 Post subject: 3d chain slider
PostPosted: Thu Apr 04, 2013 12:26 am
Anyone with some 3d skills?
Maybe 3d print some chain sliders http://www.stein-dinse.biz/Complete-par ... :2494.html
at http://www.shapeways.com/
 Post subject: Re: 3d chain slider
PostPosted: Thu Apr 04, 2013 12:37 am
I've got two friends who do that. All I need are CAD's and I could get a quote.
1988 Red Ducati Paso 750
1999 BMW R1100S
PostPosted: Thu Apr 04, 2013 7:13 pm
I am looking for two to replace I have one reasonably good one for spec'
Interested in purchasing two if any are made :thumbup:
PostPosted: Fri Apr 05, 2013 7:38 am
If you are going to get some made there are at least 2 different ones. The one on the top is a new spare part bought a few years ago and the other is of an older p750. the differences are the extra lug near the pivot end and the "nose" of the new one has been flattened off where it goes round the front of the swing arm , and the brass nut is not fully moulded into the new guide :)
Hamish
PostPosted: Fri Apr 05, 2013 1:46 pm
PostPosted: Fri Apr 05, 2013 11:59 pm
I'm also talking to someone about making these so we'll compare notes.
PostPosted: Sat Apr 06, 2013 1:07 am
PostPosted: Sat Apr 06, 2013 1:57 am
PostPosted: Sat Apr 06, 2013 7:45 am
PostPosted: Sat Apr 06, 2013 9:45 am
PostPosted: Sat Apr 06, 2013 10:30 am
True, we can get it printed in quite a few places. We could also get one carved out of dried sheep poo, chiselled from granite or cnc from billet. All of which will be the same amount of use unless the material is right for the application. Materials for 3d printing aren't exactly main stream and the sort of nylon delrin mix that a chain slider should be is really quite difficult to print.
The guy I'm talking to runs an automotive component manufacturer. Some of the components he makes are chain sliders so he already has material specs to use from some other manufacturers. He's also planning to expolore 3d with this but is not hopefully for getting a long lasting product with standard techniques. This may not be a quick solution but it could be an enduring one if it works out right.
PostPosted: Sat Apr 06, 2013 1:30 pm
