ducatipaso.org • View topic - mikuni carb conversion?
It is currently Wed Oct 28, 2026 2:00 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: mikuni carb conversion?
PostPosted: Mon Mar 11, 2013 11:28 pm
all that effort and in the end you still will have a CV carb
PostPosted: Tue Mar 12, 2013 9:56 am
model: other
year: 1999
But a more effectkve CV carb.
It will do until I get some FCRs. If the bike I find has a Weber carb, I will first test it, then take it off and study it. I will give it an overhaul in consultation with my car tuning mates and the local Weber specialist.
The Weber is an interesting performance carb and I will enjoy understanding it. They were fashionable in V8 cars when I was young.
2013 M1100Evo Street
1999 M750 "Scrambler"
2004 GSXR750 Track
PostPosted: Tue Mar 12, 2013 10:21 am
PostPosted: Tue Mar 12, 2013 2:12 pm
model: other
year: 1999
Doug Lofgren Motorcycle Performance Service website has tests for modified CV38s. He trims the throttle shafts and taper bores the body,and did internal mods to carb, but he doesnt give details. He used to do a carb overhaul for his customers.
Check out his site and the dyno tests.
A few things stand out to me.
Porting the bellmouth
Setting the float level (usually out from spec of 14mm and from each other)
Using stiff oem springs
Fitting hard needle jets from Factory Pro
Porting the long inlet manifolds but leaving a machined finish inside
They are a compromise carb because they have no accelerator pump. Dont be fooled into jetting too rich for cruise speed in order to compensate for no accelerator pump. You dont snap them open, you wind them on and they perform ok.
The manifold rubbers can crush and work like a restrictor, so its ok to trim them.
Many including myself, tried softer springs for more response, but that made us need an accelerator pump
I dont know of anyone besides DL who has modified the carb itself.
2004 GSXR750 Track
PostPosted: Sun Apr 07, 2013 5:11 pm
Do we know which inlet manifolds will/won't work with a pair of Mikunis? I've seen one Mikuni conversion for Pasos where the two carbs are split, and there is a special manifold for the horizontal cylinder which 1) allows air to reach the vertical cylinder's carb, and 2) keeps the carb float level tipped properly - a company called - even though it doesn't appear on their website, they still offer it (I emailed them; $140 +s/h) - details on this piece can be found on .
However, instead of splitting up my pair, I figured it'd be simpler to keep them as-is, and install them the way they're normally installed, between the V. Since the Mikunis don't have the same outlet trumpets that the Weber does, it appears longer inlet manifolds are in order. I found a pair on ebay for a '95 SS ... can anyone confirm or deny whether these will work appropriately?
Considering they'll be $100 cheaper than the split-carb design mentioned above, I should just give it a shot ... but figured I'd ask anyway.
1988 Paso 750 #753965
1997 Monster 750
PostPosted: Sun Apr 07, 2013 6:02 pm
model: other
year: 1999
They'll work. :thumbup:
2004 GSXR750 Track
PostPosted: Sun Apr 07, 2013 7:28 pm
:cool:
DelOrtos forever!
My 750 starts on the first turn, purrs like a pussy, and bolts like a scared cat with a pair of 36mm.
PostPosted: Mon Apr 08, 2013 12:59 am
Thanks koko64. :) Ordered!
Skins, if I can find somebody to swap me straight up a pair of Dell'Ortos for my Mikunis, I'd do it ...
1997 Monster 750
PostPosted: Mon Apr 08, 2013 3:04 am
:cool:
I think you can get new ones online for about $200 each.
PostPosted: Mon Apr 08, 2013 8:58 am
faster, are the carb manifolds you got from a 600/750 or 900 ? (they are not identical).
You can use either or, the only thing is that the carb will stand slightly shifted when using 900 manifolds on a 750. Not a problem unless you intend to make an airbox.
PostPosted: Mon Apr 08, 2013 11:00 am
model: other
year: 1999
My apologies. You are right Paso 750. The 900 heads are taller and the manifolds would be a little different.
Besides the airbox option, is the oem electric fuel pump going to be used? If the vacuum option was considere, say if someone had a crook oem fuel pump and wanted to go vacuum they would need the Monster manifolds or modify the SS manifold(drill and tap an extra hole), or put a fitting for the vacuum line on one of the synch fittings.
2004 GSXR750 Track
PostPosted: Mon Apr 08, 2013 6:02 pm
PostPosted: Mon Apr 08, 2013 7:47 pm
1997 Monster 750
PostPosted: Mon Apr 08, 2013 8:15 pm
it`s hard to tell the exact difference(s). It may be only the length but it also may be the angle, or the angle or length of the bend.
I have 750 and had 900 manifolds but it`s about impossible to say just from the looks.
Try them. Also be aware that the manifold for the front is not the same as the one of the rear cylinder.
If they are swapped you`ll see that the top angle of both manifolds doesn`t match.
swapped
correct
PostPosted: Mon Apr 08, 2013 10:40 pm
